LOC vs RCA
Old Oct 18, 2007 | 10:30 AM
shawnn125's Avatar
LOC vs RCA
I had a Kenwood amp (old and weak) but it did the job using the PAC LOC and following the DIY.
That amp started dying so I upgraded to a JL Slash 250.1V2. I used the same LOC (but the JL did not have a +12v for external which PAC LOC needed). I left the power line for the PAC alone.
Now the bass is not as loud as it was on the Kenwood (which had an auxilary +12v for the LOC).
I'm thinking of using the direct RCA splice method, but won't the output be same as the LOC w/o power?
Old Oct 21, 2007 | 11:56 PM
Gilley's Avatar
If you don't have the Bose system, don't use the RCA method without an LOC anyway. Otherwise, you will be feeding speaker level input signal into the amp.
Does the +12 volt source for the LOC have to be switched? If not, you can use the +12 volt power supply to the amp.
JustinMKN1
Sep 18, 2015 03:40 PM
yosip1115
Aug 26, 2015 10:46 AM
Thunderaan
Jul 22, 2015 07:40 PM
aorbeta
Jun 8, 2004 04:19 PM
tgenius
May 5, 2004 12:04 PM
