Ok, so where is the VSS wire plug
Old Oct 20, 2007 | 10:28 AM
noooorb's Avatar
Hey guys I'm in the middle of my Avic D3 install and have to wire the VSS. Where is the M39 plug located? I don't see anything resembling it in the bunch of plugs coming out the back of the stock head unit.
light white/green wire (Pin 18 of the M39 plug)
Old Oct 20, 2007 | 12:21 PM
JTG35's Avatar
I have a Z1 but I think it should be the same wire harness. So...ok after you plug your D3 in, you are going to use two group of wires, there will be two more group of wires left, one for the ac controller and the other has VSS wire on it. I think its green with white stripe. I will post some picture for you later.
Old Oct 20, 2007 | 06:17 PM
JTG35's Avatar
This is where i found my VSS wire as you can see the pink wire that I have connected.
Attached Thumbnails Ok, so where is the VSS wire plug-img_0953.jpg   Ok, so where is the VSS wire plug-img_0954.jpg   Ok, so where is the VSS wire plug-img_0955.jpg
Old Oct 20, 2007 | 08:01 PM
noooorb's Avatar
O ok I see. It's the M19 not M39 plug. Thanks so much for taking the time and posting pics JT. Now for that reverse wire.... (in the future I want to installa backup camera)
jeffbdye
Jun 1, 2018 03:51 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
KallDay86
Jan 8, 2016 12:42 AM
BfloG35
Oct 16, 2015 05:22 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
