Help with JL audio cleansweep install needed!
Old Oct 31, 2007 | 10:09 PM
hurricanebsball's Avatar
Does anyone know where I can splice into the front and rear speaker wires after the Bose amp with the least amount of hassle? Also, what color are the wires for each speaker? I'm installing a JL audio cleansweep for the aux input so I can hook up my Ipod for now but will add a full system in the near future.
Thanks in advance for any help.
Old Nov 1, 2007 | 06:40 AM
g35rcr's Avatar
just use the harness that connects to the amp and splice there
Old Nov 1, 2007 | 09:49 AM
Sorry for the newbie-ish sounding question but I assume you're referring to the output side of the amp? Also, what color are the wires?
Thanks for any help guys. I'm trying to get this hooked up this weekend so I can start using my Ipod!!
Old Nov 1, 2007 | 01:16 PM
g35rcr's Avatar
dont remember but just test one at a time have someone sit in the car or look it up on the manual
Old Nov 1, 2007 | 03:16 PM
caskyline's Avatar
Former Vendor
Cleansweep is not needed with our headunits. You will not get much benifit from it for the cost of it.
Old Nov 1, 2007 | 03:34 PM
g35rcr's Avatar
it will help if you are adding different speakers and amps and keeping the stock hu
Old Nov 1, 2007 | 05:14 PM
Well I already have the cleansweep cause I used to have it installed in my 04 Nissan Titan. I got the cleansweep cause the Titan has factory DVD/Nav and the cleansweep was the best option. Anyway, main reason for using the cleansweep is to save the approx $200 I would have to spend in getting something else that would allow me to use my Ipod. The cleansweep has an aux input so that is the main reason I am wanting to install it in my G.
Anyone have any info on the speaker wire color on the output side of the Bose amp?
Old Nov 1, 2007 | 06:52 PM
caskyline's Avatar
Former Vendor
Since you already have it, that is a good reason to use it. Also a easy way to add ipod. Sorry I do not have the color codes.
If you search back in old audio threads the color codes are posted.
hdmark
Apr 29, 2019 04:31 PM
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cacoepy
Aug 3, 2015 01:09 PM
Frostbite91
Aug 2, 2015 04:59 PM
