Bose radio and amp with aftermarket speakers.
Old Nov 14, 2007 | 04:08 PM
ricerocketdave's Avatar
I have MB Quart speakers from my old car (4 ohm)
I have heard that its not possible to add anything to a Bose system without changing everything. I would like to install these in the front of my car. Will this cause any issues of will it be a easy install?
I have seen the threads where people have installed the 2 ohm infinity kappas but I already have the MB Quarts so it does not make much sense to go buy new speakers if I don't have to.
Any help would be greatly appreciated.
Old Nov 14, 2007 | 05:05 PM
Gilley's Avatar
If your MB's are 6.5 components, you can install them, but the sound output will be low because of the 4 ohm rating and you may not like the volume level. So then you will need to replace the Bose amp with another amp (best plan for sound quality) or replace the MB's with 2 ohm speakers (not as good for sound quality).
Old Nov 14, 2007 | 05:10 PM
Kind of damned if you do damned if you don't kinda thing I guess..
I really don't want to replace the amp or anything. I had a lot of audio work done to my old car and just don't want to mess with all of that for a long time. I was just hoping I could replace the speakers and call it a day. I guess I could try them out and see how I like it.
If they don't work I could always go with the Infinity kappas like it seems a lot of people do here.
I was also thinking about getting these to replace the 6X9's on the rear deck.. http://mobile.jlaudio.com/products_s...p?series_id=23
Old Nov 14, 2007 | 10:14 PM
Gilley's Avatar
I don't think those JL's would be a good replacement for the 6x9's if you keep the Bose amp. They are 4 ohms and I don't think the Bose amp has enough power to push them properly.
Old Nov 14, 2007 | 10:34 PM
amazing35's Avatar
i have the bose system but only the head unit. i swapped out all the speakers. i have a jl cleansweep in my g it runs my 3 sets of a/d/s components and my 13w7. and i can plug my archos in for more music than i can ever think about listenimg to on a drive.
Old Nov 15, 2007 | 10:21 AM
Yea but if I wire them in parallel then its a 2ohm load.
What is the power rating of the Bose system?
Old Nov 15, 2007 | 11:15 AM
Gilley's Avatar
The Bose amp is 225 watts total for 2004. I have not seen the specs as to how that is distributed or at what THD%.
Old Nov 22, 2007 | 01:05 AM
NISMOTO's Avatar
How does wiring seperat 4ohm speakers produce a 2ohm load? I thought that would cause problems?! A diagram would be appreciated.
Old Nov 22, 2007 | 08:42 AM
Gilley's Avatar
^ It is basic electrical math.
parallel wiring -> 4 ohms + 4 ohms = 2 ohms
series -> 4 ohm + 4 ohms = 8 ohms
Old Nov 22, 2007 | 11:28 AM
NISMOTO's Avatar
Yes, I've seen it on DVC subs but, I thought doing it with seperate speakers caused a problem with the audio output. Never thought to try it, seems too simple a solution to acutally work.
Old Nov 22, 2007 | 01:12 PM
Gilley's Avatar
It works just like DVC subs.
Old Nov 23, 2007 | 12:36 AM
NISMOTO's Avatar
Ok, so the amp sees a 2ohm load, I'm willing to try that and expecting it to work. But how about the power output/volume? Since you'd have two speakers running off one (of the two) rear channels, wouldn't the volume still be lowered by about 1/2? Or is there a way to compensate for that also?
Old Nov 23, 2007 | 09:49 AM
Gilley's Avatar
The fact remains that the Bose amp is not very powerful to begin with.
nissandrifter32
Dec 22, 2015 04:28 PM
JoeMac
Sep 28, 2015 12:28 AM
mattdg35
Sep 14, 2015 11:28 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
