installing JUST an amp and sub
Old Dec 5, 2007 | 03:56 PM
louieallthetime's Avatar
Originally Posted by Gilley
The wires going into the Bose amp are full range. The Bose amp separates the low frequencies and sends them to the 6x9's.
Here are the wire colors.
Factory speaker harness wiring colors
Front Right + Gray/Silver
Front Right - Yellow/Silver
Front Left + Green/Silver
Front Left - Red/Silver
Rear Door Right + Brown/Silver
Rear Door Right - Black/Silver
Rear Door Left + Green/Yellow
Rear Door Left - Black/Yellow
Rear Deck Right + Blue/Red
Rear Deck Right - Blue/White
Rear Deck Left + Blue/Yellow
Rear Deck Left - White/Green
Head unit output colors
The (+) are all on the same side of the connector.
Head Output Front Right + Orange/Blue
Head Output Front Right - White/Blue
Head Output Front Left + White
Head Output Front Left - Orange
Head Output Rear Right + Blue
Head Output Rear Right - Pink
Head Output Rear Left + Teal
Head Output Rear Left - Purple
Remote Wire Light Blue/ Silver
So then yes I WOULD need to have a low impedence mod so that the only frequencies sent to the amp for the subwoofer through the RCA are lower frequencies. Correct?
Old Dec 5, 2007 | 05:00 PM
Gilley's Avatar
Doesn't your amp have a crossover? Thant's all you need to filter the highs from the subs.
Old Dec 5, 2007 | 06:08 PM
how can i tell if my amp has a crossover?
Old Dec 5, 2007 | 06:53 PM
Gilley's Avatar
It will have adjusting ***** on it. What brand and model amp do you have?
Old Dec 5, 2007 | 09:47 PM
http://www.carstereopro.com/planet_a...ERTIFICATE.htm
thats a link to what type of amp it is, and the subwoofer is a solobaric l7 15"
Old Dec 6, 2007 | 07:13 AM
i connected the wires to the blue/pink purple/teal set... and hooked everything up as normal, and im getting a lot of voice and distortion through the sub...should i have hooked the amp to the Rear Deck Right + Blue/Red
Rear Deck Right - Blue/White Rear Deck Left + Blue/Yellow Rear Deck Left - White/Green
from the white (or blue?) harness instead?? could a not good ground cause that too? i need to fix my ground as well im thinking.
Old Dec 6, 2007 | 08:23 AM
Gilley's Avatar
Your amp has a crossover.
Built in continuously variable low pass crossover (24 dB per octave)
Use a test light to make sure you have the correct turn on wire. A bad ground can cause distortion. You should be using at least 4 gauge power and ground wires.
Old Dec 6, 2007 | 11:48 AM
Eveything comes on and plays fine, it just seems like theres a lot of static and distortion still. I changed the ground spot to a better ground and the distortion went away a little bit, Im think maybe I should solder the rca cables to the harness instead of using connectors and tape...good idea? Also none of this explains why there might be voice frequencies and higher pitches coming out of the sub still... i really feel like this right now seeing as I go to school for electronic/computer engineering
Old Dec 6, 2007 | 11:53 AM
Gilley's Avatar
Did you adjust the crossover to around 60 - 70 HZ?
Solder the connections, or at least use crimp connectors.
Old Dec 7, 2007 | 03:10 PM
ok so i got everything connected, workng, and sounding good...
now my new question is what about dynomatting the trunk?
Old Dec 7, 2007 | 03:48 PM
Gilley's Avatar
Do it along with the doors.
Old Dec 7, 2007 | 05:13 PM
hurricanebsball's Avatar
Sean:
You're a good man for helping a fellow G in need!
Old Dec 7, 2007 | 05:34 PM
tbg35c's Avatar
Yeah, I can attest to that. Sean helped me big time by answering all of my questions during my audio install. Thanks Sean!
Old Dec 8, 2007 | 10:49 AM
Gilley's Avatar
I just like helping people. There are others on here with way more knowledge than me though.
Old Jan 7, 2008 | 12:41 AM
  #30
Chas87's Avatar
Originally Posted by KevinE
I just found the BOSE amp and figured out which colored wires corresponded to the left and right speaker, along with a remote line. Once that is all installed and hooked up, run your RCA's to your amp, run your speaker wires, power, ground, and BUMP!
Hey, I have an I35, im looking to do pretty much the same thing, except from the wires before the BOSE amp being spliced and running to the sub amp they are spliced and i want to run it to an equalizer to add bass back into the signal (just adding one more component into the mix) this should work right? To me it seems it would, but i like to get other's opinions before i begin the work. The equalizer i want to use is MTX Re-q http://www.crutchfield.com/App/Produ...236REQ&tp=6870
Thanks for the help!
