Can a hardwire to the home link be possible with V1 original packaging
i will be recieving a v1 soon..and i wondering if its possible to hardwire it with the home link mirror with any of the parts it comes with....
i would buy invisible cord but im anxious and want to do it asap..
I don't have V1 but I do own Escort x50 and I hardwired it directly to the homelink cable using a regular cut-off phone cable.
You can't use the original V1 wire to tap the homelink. You will need either invisicord (~$14) or in my case, I just used a regular telephone cable (black color preferrable), cut it according to my need and tapped the wires to the homelink cable directly.
Look at the image below.
Originally Posted by elvisin3d
Whats the easiest technique for doing this. Can you remove the entire mirror to get access to the cords easier? Also, you just used a regular phone cord?
I am using a regular phone cord because I have bunch of extra phone cords laying around the house. It does not cost you if you already have it and it works as well. With the phone cord, you will have to tap the green and red wires to the homelink wires.
I've had the V1 wired this way for over two years and 50,000 miles. The amp draw on the V1 is TINY. I prefer soldering as the connection is super strong. Also, there's nothing wrong with buying the a kit or using what came with the V1, but neither is hardwiring it. It's fused, on switch power and stealthy.
Originally Posted by g35rcr
make sure the fuse is strong enough for both the mirror and radar, the radar should really be wired alone with a direct wire kit from valentine...dont be a cheap as$
any install DIY for lil kit that came with the v1??
Use this as a guide:
https://g35driver.com/forums/showthr...mike%27s+mount
If you cut the extra cable open, you'll see the same red and green wires. You will have to make your own taps unless you can find taps thin enough to work, or are willing to cut open the harness wires and hardwire the cable instead of just tapping into the harness.
Hi Everyone,
We're a new sponsor here at G35driver and to celebrate we're offering 30% to all G35driver members.
Rather than splicing into your factor wiring harness or running a wire from your fuse box, the SRD cord from Stealth Cords is a discrete power cord solution that connects your compatible Radar Detector to your factory powered rear view mirror.
Our sale runs into the end of Feb - so don't miss out.
https://g35driver.com/forums/accessories-vendor/201268-30-off-discrete-radar-detector-power-cords.html
All the Best!
Thank you for your support!
All the Best!
Learned Hand
Oct 1, 2015 09:02 AM
jbmw002
Sep 10, 2015 12:54 AM
