Issue installing Infiniti Kappa Perfects
Old 01-18-2008 | 12:13 AM
PTownG's Avatar
Question
Originally Posted by n1cK
you need something like this. hope that helps. i actually have a pair that i've never used if you're interested.
I bought those adapters and the kappa 60.7cs. They are 2 ohm and from what I see the perfects are 4 ohm. Not the right match for the bose unless I am misinformed.
i haven't had time to install yet but how do those adapters go in? They are about 3/4" thick. How does that work, larger ring against the inner door panel, smaller ring out? Speakers mount underneath or on top of the adapters?
For the rear deck I am looking at kappa 692.7i. 6x9 2 way 2 ohm. Never been a fan of 3 way 6x9. I don't see the need. I'm assuming these will just drop right in. Any thoughts?
Old 01-18-2008 | 09:10 AM
Gilley's Avatar
Door < spacer < speaker
Old 01-19-2008 | 12:07 AM
PTownG's Avatar
is all that going to fit with enough clearance for the door panel?
Old 01-19-2008 | 12:30 AM
Gilley's Avatar
Of course, it's made that way. The stock speaker has a built in spacer that is removed when you remove the speaker.
Old 01-19-2008 | 01:05 AM
PTownG's Avatar
sweet
chinee
06-10-2024 08:48 PM
EnCr1pt3d
07-08-2019 03:48 PM
hdmark
04-29-2019 05:31 PM
G35Sask
Intake & Exhaust
16
08-05-2015 11:17 PM
Ashton35
07-22-2015 10:19 PM
