Questions about a new head unit
Old Apr 5, 2004 | 03:49 PM
djrobx's Avatar
Re: Questions about a new head unit
What parts would I need in order to get the Bose speakers to work properly with an aftermarket head unit.
<hr></blockquote> Just ditch the Bose amp. It's easy to remove and not worth the effort to try and integrate. You can run the existing speakers off a normal aftermarket amp just as well as you can with the Bose.
I removed the Bose amp, installed a Ven4 line converter, and for starters, just put a normal Crossfire 100x4 amp in its place. I connected the rear deck and rear door speakers in parallell. When I turned it on, everything worked and sounded almost exactly the same as it did before (that's a good thing, it means all the levels and such are balanced right). I then inserted an EQ and subs, and the existing speakers now sound wonderful in comparison. I'll eventually upgrade the components in the doors.
Tyler's03G
Aug 13, 2015 10:04 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kd03g99
Jul 30, 2015 11:24 AM
mjfenix
Jul 14, 2015 10:37 PM
