tail lights / dash lights
Old Dec 20, 2007 | 09:48 PM
johnsonhuang's Avatar
all the bulbs on my center console doesn't light up. when i turn on my headlights, my tail lights dont light up either... pretty sure a fuse went out.. but how do i check them/replace them and where do i go?
Old Dec 21, 2007 | 08:01 AM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
check your fuses....the box behind the battery in the engine compartment (you have to actually remove the battery) and the fuse box behind the driver side kick plate near the dead pedal.
doc
Old Dec 21, 2007 | 09:59 AM
oooooooooooooq's Avatar
Dont even check the fuse, just there is a little turn **** next to the vdc button, move it up and down with the heasdlights on it should work, if not than check the fuse, by any chance did your car just come back from the dealer or did you just wash it, this happened to me.
Old Dec 21, 2007 | 03:43 PM
nope, it just happened.
i read the manual and there is 2 fuse boxes.
one near my e- brake pedal and one in battery compartment. which box is it?
wonderizm
Sep 24, 2015 03:09 AM
roboeclipse
Lights
Aug 13, 2015 10:45 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
