if i replace my audio unit will i lose my bose?
Old Jan 3, 2008 | 02:05 PM
LazyAlex's Avatar
i got a 04' g35 coupe w/ the bose preiume
my question is..if i repalce my headunit for the double din touch screen navi..will i lose my bose preiume? cuz.....
when i had my lexus w/ nackamichi system...if i replaced my head unit..i loose my stock amp to my speakers and subs..does the same happen to my bose? or will it work and sound just as great w. the aftermarket head unit?..thanks
Old Jan 3, 2008 | 02:58 PM
Callaway's Avatar
You can continue using your BOSE speakers with the correct adapter. I personally dont think the stock BOSE sounds anything special. The Clarion HU in there is actually a pretty crappy unit. Adding a decent aftermarket HU will make your stock BOSE sound much better IMO.
Old Jan 3, 2008 | 03:17 PM
04G35NYC's Avatar
This is what you need to retain your bose with DD
http://www.crutchfield.com/S-bOvNBIb...h=metra+707551
Old Jan 3, 2008 | 03:24 PM
Gilley's Avatar
You would do yourself a favor by replacing the crappy Bose amp.
Old Jan 4, 2008 | 01:10 PM
LazyAlex's Avatar
thanks guys
Old Jan 4, 2008 | 01:11 PM
LazyAlex's Avatar
so u say i should get a new speaker amp? is the amp the one near the spare tire in the trunk? which amp would be a deccent one to replace that? thanks
Old Jan 4, 2008 | 02:19 PM
Gilley's Avatar
If you're getting a new head unit, for the best sound, don't use the Bose amp or the speakers. You can replace the Bose amp with whatever you like. The JL Audio 500/5 fits and works well.
Old Jan 4, 2008 | 03:46 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
depends what your goals are for your sound system....
IMO, changing out the amp and the stock speakers and keeping the stock HU will give you better sound quality.
If you want the functionality and bells&whistles of an aftermarket DD HU, then swap that out but don't expect much better quality of the stock speakers and Bose amp.
here are pictures of the stock BOSE amp
<a href="http://imageshack.us"><img src="http://img136.imageshack.us/img136/9502/image001da6.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/>
<a href="http://imageshack.us"><img src="http://img136.imageshack.us/img136/5709/image002hp6.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/>
here are pictures of the stock speakers:
notice how shallow the speakers are and how small those magnet drivers are.
<a href="http://imageshack.us"><img src="http://img182.imageshack.us/img182/237/image003hs2.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/>
<a href="http://imageshack.us"><img src="http://img182.imageshack.us/img182/4337/image004za3.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/>
look how big the Infinity Perfect 6.1 drivers and how deep the speakers are.
http://www.sonicelectronix.com/item_...fect+6.1.html#
hope this helps...
doc
Old Jan 6, 2008 | 03:52 PM
LazyAlex's Avatar
what size are thoes speakers? thanks
Old Jan 6, 2008 | 04:41 PM
docron1's Avatar
Front components are 6.5" separates with tweets
Side panel backseat speakers are also 6.5"
Rear shelf "Bose" "subs" are 6x9"
doc
Old Jan 7, 2008 | 01:31 PM
LazyAlex's Avatar
thanks
Old Apr 21, 2008 | 02:24 AM
kingrukus's Avatar
can anyone verify that this will work with a g35 coupe w/ bose audio? reason i ask is because crutchfield's site says it isn't compatible, when i select 2003 g35c w/ bose...
This is the same product as the 70-7551 on ebay correct? on e-bay, it is listed as compatible...
I would just like to be sure before i install..
Old Apr 21, 2008 | 02:42 AM
04G35NYC's Avatar
^ i have this it works.
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Frostbite91
Aug 2, 2015 04:59 PM
kd03g99
Jul 30, 2015 11:24 AM
