Is this true?
Is this true?
I have an 03 coupe with bose system, nav, every option available. I have the SAT button and will be installing a sub this week, so ill have the head unit apart. I wanted to add XM to the car, and was told by the dealer that it would cost $447.00 JUST FOR THE PIECE! Is this true? Or was he thinking of something else?! Wow, for that much, ill pay $50 and mount it custom!
I have heard of higher prices than that.
Get the kit for $249 at everythingg35.com. http://www.g35parts.com/9083/osc/pro...roducts_id=285
Check your VIN to see if you are prewired (on the everythingg35 website) and is you aren't, you'll need the $57 cable too.
It's not difficult to install it yourself.
That's the price you have to pay for a fully integrated unit controlled by the radio. Although it is still over twice what the satellite units cost for aftermarket radios.
Well, to install a double DIN head unit, you still have to spens nearly$300 for the trim piece and AC controller before the cost of the HU, harnesses, and adapters are factored into it.
It all boils down to whether you want a factory look and function. If that matters to you, it will cost a little more money.
the XM unit is that price. i would say go aftermarket if you're installing subs anyways you'll get better sound quality all around if you are going ot upgrade the rest of the speakers
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
