Installing Aftermarket HU w/ OEM XM
Im planning to get an aftermarket HU.. Is it possible to keep the OEM XM?
I have the BOSE system, can I hook up the HU to the stock Bose amp with the correct harness? Part numbers will be greatly appreciated.
OEM XM or Sirius won't work with an aftermarket HU.
You can connect an aftermarket HU to the Bose amp (but the Bose amp is the weak link of the system). It will depend on your HU as to how you connect it.
Search some posts and you'll see the options.
Yea, if you wanna know what you will loose go to Outfit my car @ www.crutchfield.com and you can pick different HU, and it will tell you what you will loose...
FS[NorWest]: 04 OEM Faceplate and CD/Tape Unit
Oregon13
Audio/Video/Electronics
Mar 1, 2016 12:06 AM
FS[NorEast]: New OEM G35x Compression Rods - Save!!
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
Learned Hand
Oct 1, 2015 09:02 AM
