Why do FX's set my V1 off when we pass?
Old Feb 13, 2008 | 07:44 PM
Dubfound's Avatar
In my town a few people have an Infiniti FX and when I pass them my V1 goes off! Everytime when I pass them in head on traffic. It does not beep it will siren off. Does this have anything to do with the FX's cruise control?
Old Feb 13, 2008 | 07:45 PM
rookie's Avatar
Pretty sure it's the ICC (intelligent cruise control), QXs and some of the new S600s set mine off.
Old Feb 13, 2008 | 07:53 PM
Klubbheads's Avatar
there was a new S63 that set mine off too, it was a K-band.
Old Feb 13, 2008 | 07:54 PM
rookie's Avatar
Really? I have a S600 at work and it has that cool cruise control system. Never really thought what band that would be on, thought it would've been laser. The nightvision thing on those is cool.
Old Feb 14, 2008 | 01:11 PM
rroyter's Avatar
QX sets off laser on my V1. Kinda annoying but ignorable.
Old Feb 15, 2008 | 05:12 AM
Meatshackle's Avatar
Deep Sea Moderator
The FX's and QX's with the laser controlled cruise will set mine off. Some of the newer LED taillights set my laser off as well when I'm behind them at a stoplight.
Old Feb 15, 2008 | 08:46 AM
GreenGoblin's Avatar
The goblin resurrection
thats pretty cool how advanced some of those systems are tho
Old Feb 17, 2008 | 12:27 AM
akochman's Avatar
If it is Laser that you are getting on the V1 then it is most likely the other cars ICC setting it off. There was a QX in my neighborhood that used to set my V1 off every time I drove by.
Old Feb 17, 2008 | 03:48 AM
Element G35's Avatar
everytime i floor my car or down shift it while im braking it sets off my LASER, it's fu^k!ng annoying!! I have an escort passport 8500, anyone know why this might be?
Old Feb 17, 2008 | 03:49 AM
why would someone be using their cruise control in a neighborhood
Old Apr 12, 2008 | 01:43 PM
Gordgee's Avatar
Administrator
It might be your Escort 8500. It may be sensitive to voltage fluctuations. Set it in 'voltage display' mode and see if the voltage changes (though I'm not sure how accurate or how quick the refresh is).
Old Apr 13, 2008 | 09:24 PM
dradef's Avatar
I have sort of the same thing with my 8500 on my Yamaha R6, anytime revs go over about 12,000 the thing alerts laser. I finally just turned of laser detection, the way it is mounted won't allow it to pick up laser signals anyway. Not exactly sure why, mine is most likely interference due to being so close to the engine control module and ignition coils.
Old Apr 16, 2008 | 01:01 AM
Joe_Camel's Avatar
If the engine is on, the lasers are on, they don't actually have to set the cruise control.
Old Apr 16, 2008 | 10:13 AM
Armanius Maximu's Avatar
I read in Car and Driver that the laser in the ICC in the Infiniti's are "on" even when you are not using the ICC. So in theory, if you have the tech package with the ICC in your car, you can set off your own radar detector when the laser signal bounces back to your own car after reflecting it off a car in front of you.
Does anyone with ICC and with a radar detector experience that problem -- setting off your radar detector b/c of the laser in your Infiniti's ICC?
I want to buy a V1 or a 9500i, but would be annoyed as hell if my own car is setting off my radar detector!
Old Apr 16, 2008 | 03:32 PM
ckg35's Avatar
If it's a real issue, if the ICC you could is laser based, you could cover the transmitter of the ICC section if that feature is unimportant to you, or if it is, turn off the laser detection on your Valentine.
