AVIC Z2 question
You will need the dash finisher, ac controller and maybe this other bracket. You will have to solder the dual climate button to the new ac control unit but other then that its pretty easy.
http://www.grubbsperformance.com/servlet/Detail?no=3060
If you want to keep running off the stock amp.....you will need to buy a wire harness (Scosche NNO3B) and an antenna adaptor also (not sure which one I went with, but I think you can buy it from Nissan or Scosche: http://www.scosche.com/scosche/antennas/NDAR.asp). You can find both items on ebay, which is probably your best bet! Good Luck with the install!
Originally Posted by Moog
What about wiring?
to retain steering wheel controls...PAC swi-ps
and....antenna wire adapter(OEM plugs are different size from aftermarket)
Originally Posted by Deezflip
to retain factory bose amp...Metra wire harness 70-7551
Does the z2 unit fit perfectly into the JDM double din dash kit or will we have to fabricate some type of trim ring? Just want to make sure it fits without any gaps surrounding the unit.
What about wiring?
it fits perfectly into the jdm dd kit. no fabricating at all.. actually looks like the car came with it from factory.
Originally Posted by g35rcr
the z2 fits into the double din kit pretty well no need to fab up anything
