Ipod Integration Kit Problems
Old Feb 27, 2008 | 02:16 AM
xiphilix's Avatar
Angry Ipod Integration Kit Problems
I ordered and installed the Ipod Integration kit that I bought from Infiniti for my 03 Coupe (and YES it is pre-wired for Satellite, but I DON'T have Satellite Radio). Got a PDF of the install which was a breeze since it was in the trunk and pretty much plug and play. Now when I plug up the Ipod it Says "Okay to Disconnect" which is what it's supposed to say, but the only problem is my Bose 6-Disc CD Player isn't detecting it when I push the SAT button. Has anyone had this problem or knows how it can be resolved? Thanks in advance
Old Feb 27, 2008 | 03:43 AM
marcinr's Avatar
20 Year Member
It doesn't use the sat button. Press your CD button a couple of times or the input button on your steering wheel.
Old Feb 27, 2008 | 07:40 AM
Gilley's Avatar
Mine uses the SAT button to change to the iPod.
Old Feb 27, 2008 | 11:22 AM
Capitol G35's Avatar
I had the same issue and I have the same setup as you. When I plugged the unit in it didn't work when I pressed SAT. I tried all that "voodoo" button pushing and nothing worked. I ended up having to send it back. I felt bad because nowhere on G35 Driver anyone else had similar issues. I thought about taking the G to the dealership to get it checked out but I said screw it and bought a DD Eclispse Aftermarket HU for a good price.
Old Feb 28, 2008 | 03:03 AM
xiphilix's Avatar
I'm glad someone finally ran into that same problem, I wonder if it's the CD player or if it's the Ipod integration kit? Damn, guess I might have to sell it then since i bought it last month
Old Feb 28, 2008 | 08:27 PM
jalilig35's Avatar
i have 05 and i press radio button to bring it to the ipod, dont know if its the same with the 03
Old Apr 14, 2008 | 01:41 PM
RicoG35x's Avatar
I just installed mine in my 04 G35x... I simply press the SAT button from either the dash or the mode button on the steering wheel.. and away it goes!
What I NEED.. is to figure out how all of the other buttons work to toggle through the different display modes.. I didn't get any kind of instructions with my kit.. it actually looked used.. but it works.
One thing I found is that when I try to use the forward/back button on the wheel.. it only toggles what looks like the little CD icons on the HU display for the CD Changer.. i have to use the button on the radio to toggle through the songs... otherwise.. it sounds SWEET!
Old Apr 23, 2008 | 09:47 PM
NETSHARK's Avatar
Yooo man just HOLD the Buttons you used to change tracks with (in CD Mode) just like if your changing the CD and then the song will change to the Next one !! am sure i`ve tried it and it did work !!! my iPod is the 6th Gen (iPod Classic) my car is 2004.5 Coupe.
chinee
Jun 10, 2024 07:48 PM
chinee
Aug 8, 2015 10:11 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
bishop977
Audio/Video/Electronics
Jul 31, 2015 02:29 AM
