wiring harness for alpine
Old Mar 23, 2004 | 01:21 PM
e3utxk's Avatar
I'm contemplating buying a 6MT but wanted to make sure i can upgrade the factory stereo to the new MP3 jukebox from Alpine (HDA-5460) with the HU (CDA-9827) and an Alpine XM tuner.
Looks like the double din from Yosi's garage will do the trick but where can i get a wiring harness? Scosche said the NN03 may work.
True? Any other alternatives?
thanks
Old Mar 23, 2004 | 01:36 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
Re: wiring harness for alpine
GO with NNO3... I used that for my conversion, works well. Everything's color coded and easy to crimp.
The only thing you'll have to probably run is the blue/white stripe 12V 12G Lead Amp wire from the back of the alpine deck to your amp's remote power terminal.
Old Mar 23, 2004 | 04:47 PM
docron1's Avatar
You can get the Scosche wiring harness from sounddomain.com
http://www.sounddomain.com/sku/SCONN03B
Don't forget you'll need the antenna diversity adapter for Nissan. The alpine antenna plug on the back of the deck will not receive the stock Nissan/Infiniti antenna cable. You use the adapter to connect the stock antenna to the antenna plug on back of Alpine or any other aftermarket deck.
http://www.sounddomain.com/sku/SCONDAB
Hope this helps.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Picture Share
Feb 4, 2018 12:41 PM
the93owner
Sep 28, 2015 10:37 PM
