Bose Stereo and Climate Controls Kind-of Dead
Old Mar 24, 2008 | 12:43 AM
fbw5595's Avatar
This problem has grown in my car in the past month. Shortly after starting the car, the buttons that control the Stereo and Climate controls stop working. They still light up, except for the radio station display and the current mode of the climate control.
The systems does work. By this, I mean that I can adjust the stereo via the steering wheel. I cannot adjust the climate, but if it is "frozen" on auto mode, it will cycle through.
What is the matter? Does anyone know how to fix it?
Links?
-FBW
Old Mar 24, 2008 | 02:41 AM
Beebo's Avatar
sadly this is quite a commen problem with the G's... i believe the only fix would be the dealer...
Old Mar 24, 2008 | 08:15 AM
Gilley's Avatar
It sounds like your circuit board for the AC and radio died. If your car is still under warranty, take it in for a new radio.
Old Mar 24, 2008 | 08:36 AM
fbw5595's Avatar
Sadly, my car is not under warranty and I did not extend it. Any estimates on a new radio/ circuit board?
Old Mar 24, 2008 | 11:29 PM
Beebo's Avatar
i believe $1000+... time to go aftermarket
Old Mar 25, 2008 | 11:22 AM
fbw5595's Avatar
AF has to be more expensive.
Old Mar 25, 2008 | 12:36 PM
Boston's Avatar
I have an OEM HU that I just pulled from an 03.5 coupe. It's a Bose with SAT option. The circuit board is attached to the HU. PM me if you're interested. I'll be posting it for sale next week.
Old Mar 26, 2008 | 12:02 PM
G-Rated's Avatar
this was the reason why i went aftermarket same thing happen a few times i just couldnt duplicate the problem to the dealer... i do love the stock look...
Old Dec 11, 2008 | 01:32 AM
TonyF's Avatar
incase you haven't fixed the problem yet, i've been experiencing the same thing. the circuit board might be o.k. but the ribbon that is attached from the stereo HU to the face may be damaged. this will happen if you have removed your stereo before. if you mess around with ribbon and get it to connect correctly, you'll get everything working just fine.
although i got my stereo and AC controls working again, i've had a bigger problem getting the stations to display. i just gave up on that.
Old Dec 26, 2008 | 11:20 PM
JOEYD0730's Avatar
correct, the poblem is in the ribbon cable that attaches the panel to the radio. it is a very common proble. most times it can be repaied by taping the cable to the bottom of the radio.
JoeMac
Sep 28, 2015 12:28 AM
mattdg35
Sep 14, 2015 11:28 AM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
