Help! No power to NAVI,Stereo or HVAC
Old Mar 29, 2008 | 04:51 PM
TDotKnight's Avatar
Hi guys,
I just picked up an 04 coupe about a week ago. Yesterday when I was driving I tried to charge up my phone using the cigarette adapter, it wasn't working so I figured it was the fuse. So today I looked at the fuse and everything seemed okay, so I plugged in the unit again and then I lost power to most of my electronics. My stereo isnt working (stock unit) HVAC system is running but I can't adjust any of the controls and there is no power to my Navi, as well I can't see my gauges light up (its day time so I can't really tell) but can any one help me out? Did I blow a fuse? Or did I short the circuit board? Any help would be great
Thanks in advance
Old Mar 29, 2008 | 05:29 PM
Gilley's Avatar
You probably blew a fuse. Either your charger has a short in it or the power receptacle has a short.
Old Mar 29, 2008 | 05:44 PM
TDotKnight's Avatar
I took a look at the fuses, they seemed okay, but I will try replacing them. I really don't care too much about the cigarette lighter, I want to get power back to my other stuff. I'm hoping its not the circuit board because I heard that cost about $300 + labour..
Old Mar 31, 2008 | 11:37 AM
Rocket1991's Avatar
I have an 06 Coupe and i had a similar problem. Check fuse 6 in the driver kick panel. the one labeled "mirror"
Old Mar 31, 2008 | 11:41 AM
TDotKnight's Avatar
I'm gonna check all the fuses tonight and see if any of them are blown. thanks for all the help guys, I really appreaceate it.
Old Mar 31, 2008 | 11:52 AM
G-Rated's Avatar
remember theres also a fuse box behind the battery...
Old Mar 31, 2008 | 12:11 PM
sleeper22's Avatar
Funny my AC is not working now. I had a Satellite Radio hooked up Saturday and for some reason something told me to check out the AC. The compressor will not kick on or blow cold air.
Old Apr 1, 2008 | 11:28 PM
TDotKnight's Avatar
Sup guys...I booked an appointment with the local Infiniti dealership for 2mrw...so I said let me jus try checking all the fuses one more time...and I found one that was blown! ( the mirror fuse)...so I changed it and still nothing was working...then I realized that some fuses were not in their proper slot...so i put everything accordingly and everything worked! Saved me some time and money! Who ever set up the fuses last time (i'm guessing the dealership I bought it from) didn't do a good job...but everything is working now... Thanks guys for all your help
Old Apr 2, 2008 | 07:13 AM
sleeper22's Avatar
Old Apr 2, 2008 | 07:33 AM
Gilley's Avatar
Glad you found the problem.
NailBomb
Oct 28, 2015 07:53 AM
vamarris
Sep 26, 2015 12:56 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
2014g35x
Sep 11, 2015 07:53 PM
