SET light randomly blinking?
Old Apr 3, 2008 | 09:46 AM
chobble19's Avatar
Question SET light randomly blinking?
For the second time in about a month the green SET light starting blinking as i was pulling into work yesterday. I have absolutely no idea what could cause this to happen. I turned the car off and back on a couple times and it still flashed. After letting it sit for a little bit it went away. This also happened once before and went away within a day. I never use my cruise control so i dont think that could have something to do with it. Anyone else experience this issue??
Old Apr 3, 2008 | 10:37 AM
k_hojnacki's Avatar
Do a search...it has been covered in the past pretty indepthly (sp?). I had a similar issue and was due to moisture getting in through the wiring harness entry in the cabin running down to my TCM and ECU.
Old Apr 3, 2008 | 10:41 AM
chobble19's Avatar
i did search came up empty handed...what issue did u have? and what solved ur problem?
Old Apr 3, 2008 | 11:11 AM
k_hojnacki's Avatar
https://g35driver.com/forums/g35-sedan-v35-2003-06/136519-set-cel-light.html
Old Apr 3, 2008 | 11:34 AM
chobble19's Avatar
thanks i was searching in the wrong area. i just checked my ecu and there was no signs of moisture or water at all. i even pulled the carpet a little. i used to have grounding wires i ran through the rubber grommet but the whole was so tight seemed like it sealed itself. i am going to plug it up hopefully this solves the problem. thanks for pointing me in the right direction
Old Dec 27, 2010 | 01:52 PM
RDUBPhoto's Avatar
Did you find the fix for this issue? My set light only starts blinking when I turn on the cruise control. Car is running fine, not sure what the deal is.
Thanks for any help. Much appreciated.
Hasanbaloch
Feb 29, 2024 08:45 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
BlueBelleG35x
Jul 23, 2015 02:10 PM
kenthung
Jul 21, 2015 05:56 AM
