Step by Step
Old Apr 7, 2008 | 12:56 PM
OBG3506's Avatar
Step by Step
Is there anybody that could point me in the right directions of hooking up a DD in an 06 at? the reason im asking is because the pics on the DYI are all distorted! i just need to know if the wiring is striaght forward! im going to do this myself cause every shop i talked to act as if im asking them to by the farm, expensive! so i figured since there is no soldering involved now, that i could tackle this. so any insight or pitfalls would be greatly appreciated or which wires hook to what! im looking at that kenwood 7" touch screen navi system!
~Thx!
Old Apr 7, 2008 | 01:03 PM
Gilley's Avatar
Do you have the Bose system? If so, how do you plan to connect it to the Bose amp. There are several ways.
Old Apr 7, 2008 | 02:15 PM
OBG3506's Avatar
Gilley thats the thing im trying to get a handle on whats the best way, hell and im color blind! yes i have a Bose system and would like to make use of the bose amp.
one other thing is there a pic that show the wiring hook up from the HU to the adapter harness? not being lazy colors just mess with me and i dont wanna mess this up!
Old Apr 7, 2008 | 06:01 PM
Gilley's Avatar
I understand your situation. I have a little green/brown colorblindness myself.
If I were you, I would use the RCA outputs from the Kenwood, cut a short RCA cable hin half, strip the bare ends, use the Nissan wire harness adapter, and and connect the stripped ends of the RCA cables to the wire harness adapter, which will send the low level signal through the OEM harness and into the Bose amp. Some wire harness adapters have writing printed on them telling you what each wire does, in addition to being color coded.
Old Apr 8, 2008 | 08:27 AM
OBG3506's Avatar
reading around i read that the rca cables give off alot of hiss.
~Thx!
Old Apr 8, 2008 | 11:48 AM
Gilley's Avatar
Not in either of my cars.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
ZoominG35
19 Inch
16
Oct 30, 2015 05:44 PM
wow600rr
Sep 28, 2015 11:50 AM
Jon81035
Sep 16, 2015 04:58 PM
