Sirius Satellite help!!
on
Originally Posted by Marksimus
I mounted my antenna on the child seat bracket on the driver's side of the rear deck. I took off the plastic clip that covers the bracket and let the antenna stick to the metal bracket (your antenna should be magnetic). I usually get a full signal (I have a Sporster 5).
Perhaps you could try that?
on
Originally Posted by G35Sask
I might have to. I figured the 6 inch galvanized steel disc might do the trick like others.
Didn't work for me, same problem unfortunately. I was hoping someone might be kind enough to take a photo of their antenna set up so I can compare to mine, maybe I have bad placement or something.
on
So its not touching the glass or anything? I have mine touching the glass with the antenna also very near the glass.
Here are a couple pictures. Sorry its dark and they didn't come out great. I tried with the antenna right touching the glass and back 4-5 inches. Heres an idea of what I am trying and not getting much luck with signal holding.
