Steering wheel controls with aftermark DD
Old 04-10-2008, 03:31 PM
acsracing's Avatar
Is there anyway to make that work?
I'm thinking of getting the eclipse 6620 or the Z1/Z2 from pioneer.
There isn't much information online for those about making it, just wondering if anyone has done it.
Thanks,
Adam
Old 04-10-2008, 03:34 PM
hpric's Avatar
you'll need a PAC adaptor (Part Number: SWI-ECL2) for Eclipse. Here is the site with info http://www.pac-audio.com/products/pr...rface#SWI-CAN2
Hopefully I'm not violating any rules by posting
Old 04-10-2008, 04:51 PM
Boston's Avatar
Or the PAC SWI-PS for Pioneer or Sony.
Old 04-10-2008, 07:29 PM
az1anbeethoven's Avatar
for the eclipse, i used the PAC-Swix
Old 04-10-2008, 09:53 PM
Gilley's Avatar
The SWI-X is the universal model with the remote eye. It works like a remote control. The other models connect directly to the rear of the HU.
Old 04-11-2008, 08:50 AM
hpric's Avatar
I'm hooking mine up tomorrow, does anyone know which harness contains the SWC wire that I need to tap into? I see a harness that is not connected to anything anymore since I changed to an aftermarket radio and I'm wondering if the white wire on that harness is the one that I'm suppose to tap into
Old 04-11-2008, 10:32 AM
Gilley's Avatar
It is the harness with the fewest number of wires. I think there are 4 wires only.
Old 04-11-2008, 01:14 PM
hpric's Avatar
not sure about that, the site and instructions say the plug has 30 pins and I just checked with the installer at Sound Advice and he said there is another plug located a little further down in thats where is needs to be tapped into. I'll check it out tomorrow and let you know if that was the case
Old 04-11-2008, 01:17 PM
acsracing's Avatar
Thanks for all the help
Old 04-11-2008, 04:14 PM
Gilley's Avatar
There are fewer wires than there are pins.
There are 4 plugs that go into the back of the OEM radio - two for power and speakers, one for satellite radio, and the 4th is the steering wheel controls.
Old 04-14-2008, 09:26 AM
hpric's Avatar
I'm not seeing 4 plugs, I see 3 plugs (two for radio, one for Sat)
I even went to two Circuit City's and Two Best Buy's and none of them could help me. I have the unit grounded and connected to power so the only thing left to do (hopefully) is connected the final wire (white) to the SWC.
I have to get this thing down asap because I moved my radio to the upper glove box so I'll have the dash ready for my touchscreen
Old 04-14-2008, 11:13 AM
Gilley's Avatar
The 4th connector is there somewhere.
Old 04-14-2008, 01:27 PM
hpric's Avatar
Ok, i think I know what is going on here. I looked a little closer at the wire bundle and decided to unwrap it and confirm the wires inside. It appears the previous owner had a a SWC adaptor installed previously and had cut the plug from the harness and installed some resistors. I have four wires that have resistors on them and one of them is white with a green stripe I think. I'm gonna try and hook this up again tonight and I'll get back with more results
Old 04-14-2008, 03:35 PM
Gilley's Avatar
That's probably why you don't have the 4th connector.
Old 04-15-2008, 10:27 AM
hpric's Avatar
OK, I connected everything up (power,ground and white wire) according to the instructions and still nothing. I'm wondering if my SWC are bad
Quick Reply: Steering wheel controls with aftermark DD
