connecting multiple amps???
Old Apr 14, 2008 | 04:41 PM
jaydafunk's Avatar
I currently have the BOSE system with an amp & sub connected via LOC. I want to connect another amp for the 6 1/2's inside. I'm figuring i can connect it the same way as far as the power, ground and remote. But not to sure of what speaker wires to run to the amp. I sure dont want to have to run new speaker wires from all 4 doors to the amp. Any input would be greatly appreciated.
Thanks
Old Apr 14, 2008 | 07:31 PM
nebbie81's Avatar
you should be able to get the speaker wires from the bose amp
Old Apr 14, 2008 | 09:35 PM
Gilley's Avatar
What HU outputs are you using for the sub amp?
Old Apr 15, 2008 | 06:24 AM
jaydafunk's Avatar
im using a LOC which is connected to the rear speakers.
Old Apr 15, 2008 | 09:24 AM
Gilley's Avatar
Then connect the other amp to the front speaker outputs.
Old Apr 15, 2008 | 12:38 PM
keegur's Avatar
well you can get a 4 channel amp and power all your speakers and use a 4 channel LOC so you dont lose all the features
Old Apr 15, 2008 | 04:48 PM
jaydafunk's Avatar
-what speaker wires would i connect to the 4 channel amp?
-would i just tap into the 4 speakers and make the wires longer and run them to the amp?
-since i have the sub amp connected to the rear speakers can i use a 2 rca Y adaptors into the current LOC so that i can keep the fade?
Old Apr 15, 2008 | 06:00 PM
Gilley's Avatar
Is your sub amp inputs conncted straight to the rear speakers?
You can tap into the front and rear audio signal from the HU at the Bose amp.Get the signal BEFORE it enters the bose amp.
Old Apr 15, 2008 | 06:29 PM
jaydafunk's Avatar
^they are connected to the rear speakers via LOC
Old Apr 15, 2008 | 06:56 PM
Gilley's Avatar
Then tap into the audio signal at the Bose amp. Your sub will perform better if you get the signal there too - before the signal goes into the amp.
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
