sound deadening worth is in a coupe
Old Apr 16, 2008 | 11:49 PM
Initial-G's Avatar
Like the title says. What are peoples thoughts on sound deadening material and what did you use?
Old Apr 16, 2008 | 11:58 PM
releasedtruth's Avatar
Definitely worth it if you like pain and suffering. It's not much fun really. I've used B-quiet, brown bread, fat mat and Dynamat. I'll say that Dynamat extreme is the best and most expensive I've used. Fat mat is decent, but has limited holding power in Tucson heat. Lot of asphalt smell for a good while too. If you're taking the panels off to do speakers, do it. Diminishes road noise and does wonders for speakers as well.
Old Apr 17, 2008 | 12:17 AM
ModMe's Avatar
I took my entire car apart, including the carpets and deadened the entire car with Raamat. Then I covered everything with a layer of ensolite. Then I filled up every single gap in the car with foam. The car is so much more quieter now. You can actually hear what the passenger in the back are saying while on the freeway.
Old Apr 17, 2008 | 12:42 AM
kernel's Avatar
SEC > Big 12
how much does doing something like this cost?
Old Apr 17, 2008 | 03:41 AM
Meatshackle's Avatar
Deep Sea Moderator
You can get the bulk packs of Dynamat for a little over $100. It's the time really. Lots of rolling, cutting, and more rolling.
Definitely worth it.
Old Apr 17, 2008 | 08:16 AM
jon.cole's Avatar
go with raammat from raamaudio very cheap and very good!
Old Apr 17, 2008 | 09:21 AM
I like the dynamat extreme trunk kits for value if you go the dynamat route. Bunch of good products out there, but drawbacks to each
Old Apr 17, 2008 | 12:32 PM
KAHBOOM's Avatar
I am thinking about putting sound deadening materials in my trunk- particularly becaue I want an exhaust system but I don't want to hear it at highway speeds. Does anyone have experience or feedback on the incabin sound of the exhaust after installing dynamat or other products?
Old May 1, 2008 | 02:55 PM
Ghayes23's Avatar
^I'm wondering the same thing. Anyone?
Old May 10, 2008 | 10:07 PM
PTownG's Avatar
I just ordered a roll of raammat, 3yards of ensolite and a can of spray adhesive. $176 shipped but it should be enough to do the whole car.
I've had a pair of infinity 62.7i and another pair of 692.7i sitting under my bed for 3 months waiting for me to get up the energy to gut the rear interioir to replace the stock bose garbage.
I figure if i am going to do it i might as well deaden while it's apart. It would be stupid to tear that all apart twice.
I did plenty of research. Seems raammat is the best bang for the buck and easy to work with. I'll let you know next weekend how it works out.
Old May 11, 2008 | 04:26 AM
jalilig35's Avatar
doesnt this stuff weight like a ton?? anyone notice car alot heavier?
Old May 11, 2008 | 05:30 AM
Deep Sea Moderator
I didn't notice a change. It might have something to do with adding 160whp also.
Old May 11, 2008 | 11:23 AM
PTownG's Avatar
50' roll of the raammat weighs about 22 lbs. I wouldn't consider that a lot of weight.
Old May 12, 2008 | 12:10 PM
ENVYMYG's Avatar
Diet and lose 22 pounds. Problem solved.
Old May 12, 2008 | 05:57 PM
mpapers's Avatar
will my trunk rattle if i dont use this stuff? I dont want to sound like a idiot driving down the street? im putting in 1 jl 10w6 in a zenclosure box.
