Help with V1 hardwire install
Old Apr 18, 2008 | 06:40 PM
Joe Fro's Avatar
Hey all, My name is joe and I think this is my first post here. A little background, 2005 DG G coupe, Ztube w/ JWT Pop charger, APEXi super grounding kit, and a V1 radar detector which is the reason for this post. I am attempting to hardwire it and have clamped to the thick black wire that is screwed to the back of the cig lighter and grounded to a bolt under the glove compartment that is conected to a metal bracket. I STILL DONT HAVE POWER!! Argh! The fuse is good. So I haven't a clue as to what's not right. Any help is appreciated.
Old Apr 19, 2008 | 10:10 AM
Gilley's Avatar
Are you sure that black wire is for power?
Old Apr 19, 2008 | 10:57 AM
Meatshackle's Avatar
Deep Sea Moderator
I was thinking the same thing.
Old Apr 19, 2008 | 12:28 PM
kernel's Avatar
SEC > Big 12
Dude forget the hardwire kit that it comes with, I tried that and realized it was a huge mistake. Just get this.
Old Apr 19, 2008 | 12:33 PM
paulg35s's Avatar
Your best bet is to use an add-a-circuit from autozone. You will need the smaller sized one and buy an extra 10amp fuse. Get to ur fusebox in the kick plate, pull one of the fuses, put the addacircuit in and run the power wire to it.
Old Apr 19, 2008 | 09:39 PM
LT1 SS's Avatar
^ add a circuit
Old Apr 19, 2008 | 09:46 PM
dofu's Avatar
20 Year Member
If you're using a wire tap like this...
Be sure that the metal actually went throught the plastic and has contact with the actual metal wire inside.
But I don't think any black wire has power...
Old Jul 26, 2008 | 12:19 PM
AUSS1E's Avatar
black should be the ground to the chasis
Old Jul 26, 2008 | 12:23 PM
homelessdrunk's Avatar
Originally Posted by LT1 SS
^ add a circuit
+1 easier to do rather then doing what your doing. less of a mess imo. after running behind the headliner and the a pillar
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
