FM Antenna after DD Install? Help!
Old Apr 7, 2004 | 04:25 PM
cloudkid's Avatar
After my DD install, I used an adaptor for the FM antenna so it would hook back up into with the factory one. Well, not only is the range worthless but so is the sound. I think this might have been covered in the past but no luck finding it. Anyone have any good ideas or suggestion's out there that has installed the Double Din? Thanks a bunch.
Old Apr 7, 2004 | 05:26 PM
mstil35's Avatar
Re: FM Antenna after DD Install? Help!
Did you install a Kenwood unit? The FM reception on mine is so bad that I had to patch the Bose unit into the aux. input of my Kenwood to be able to listen to FM!!!
I have the Kenwood KVT-911 dvd/tv/tuner
Old Apr 7, 2004 | 06:35 PM
xswl0931's Avatar
The FM Antenna adapter is one thing, but you also need to make sure you hooked up the powered antenna signal wire. The G35 has a powered antenna so you need to let the car know when to power it up, otherwise it's not "on".
Old Apr 7, 2004 | 06:39 PM
g35mt's Avatar
i don't recall but there is a wire that you need to connect from the after market head unit to the factory wire. I post the same issue before and some point me with a diagram showing which wire need to be connected.
Basically the antena need a power source. By removing the bose unit, you no longer supply the power to the antena. What you need to do is get the blule/white(Power antena) from the head unit and connect to one of the wire from the factory head unit (i think it was green/white). I am not sure this is correct for all car, but before you do it, check the thread that contain the information. Do a search on it, cause i don't remember exactly what the wire color.
g35mt
Old Apr 7, 2004 | 06:57 PM
orljmh's Avatar
Does anyone know the Antennae adapter brand and part number?
Thanks.
J.
2004 G35 Coupe 6MT
Volk GT-7's/ TEIN Basics
Falken 245/35/ZR19 & 285/35ZR19
Kinetix Racing Camber Rods/ K&N Typhoon CAI
Old Apr 7, 2004 | 07:48 PM
cloudkid's Avatar
I installed an Eclipse 8443. Hopefully I will locate your post on it. I remember seeing it awhile back but took forever finally to get the install completed it was pages ago. Thanks for the input guys. Everyone is always so helpful here.
Old Apr 8, 2004 | 01:14 AM
mvorion's Avatar
Just finished installing a Kenwood unit this evening. AM/FM reception is fine. I connected the power ant lead from the kenwood harness to the infiniti one. I also installed the Scoshe NDAB antenna adapter.
http://www.sounddomain.com/sku/SCONDAB
2004 G35C 6MT DG/G | Premium | Alum Pedals |Huper Optik 30/40/50 | Z-Tube | K&N Drop-In | Grounding Kit
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
