VSS Wire Location On 2003 G35 Sedan Please Help.
Old Apr 22, 2008 | 04:02 PM
ORTIZVLADIMIR's Avatar
I am trying to install the avic D3, but I dont know where to connect the pink car signal speed wire. Does anyone have a picture of this wire?THANKS!
Old Apr 22, 2008 | 04:19 PM
Deezflip's Avatar
https://g35driver.com/forums/audio-video-electronics/185759-vss-wire.html
Old Apr 22, 2008 | 05:15 PM
Thanks for your quick reply Deezflip but im still at a loss for where that wire is. Im suprised that their isnt a pic anywhere of its location in this forum. Ive been looking for awhile and am trying not to get frustrated.
Old Apr 22, 2008 | 09:39 PM
Can Anyone Help?
Old Apr 23, 2008 | 01:56 PM
Deezflip's Avatar
I'm not sure if it's the same for the coupe and sedan, but on my coupe(with bose and no navigation) it's off of one of the original factory harness plugs that you disconnected from the bose headunit, the plug that had only four wires. Do you have the bose unit? navigation?
If i remember correctly, mine was off-white/green...more like gray/green. Seems like mine had some discoloration of some sort.
The other 3 wires should be Red...Green...Yellow, if my memory is correct. If you see these three wires and the white/green(maybe grayish/green wire), then you should know that you have the plug that has the VSS wire.
Old Apr 23, 2008 | 09:28 PM
THANK YOU! I know which one your refering to. Iwill try it tomorrow.
Old Apr 23, 2008 | 09:46 PM
Deezflip's Avatar
remember that since there will be other "red" or "green" wires on other harness, just make sure you have the harness with ONLY four wires on it and you'll be good to go. Goodluck
Hasanbaloch
Feb 29, 2024 08:45 PM
Augy
Steering & Suspension
Sep 8, 2015 12:53 AM
Tom_P
Jul 24, 2015 04:05 PM
Chattzx
Jul 17, 2015 11:23 AM
