Problem with instrument light "REV"
I am the proud new owner of an 06 6MT (fewer than 24 hours). The one question that I had that the seller could not answer for me is why there is always a dash light right in front of me that says "REV". The manual says that is where the auto gear indicator would be but I have the standard. And I'm definately not going in reverse. Is it just a malfunctioning light? Thanks in advance.
the rev is for the 6mt it is a shift light that comes on when you set the rpm you want. it is a little red light that blinks. to set it higher you have to push the trip button till it comes to the setting then set it to like 6500 or 7000ish
