Need a speaker recommendation
Old Apr 13, 2004 | 03:45 PM
tgenius's Avatar
Re: Need a speaker recommendation
JL Audio XR650Csi's for front door and tweeters are wonderful speakers.. a lil pricey..but worth their price (having my old ones installed in my sedan in the next couple weeks.)
2004 G35s 5AT DG/Graphite/Premium/Huper Optik Tint
Old Apr 13, 2004 | 06:29 PM
GurgenPB's Avatar
some very good suggestions, you guys are great.
But I do not have any money left over from wheels/TT to spend on a "good" system. Again, I am not an audiophile, just looking for clarity. I do NOT even have an amp (I've got the stock NON-Bose system).
Infinity Baselink kind of grabbed my attention - I have seen it on a sedan. It's a self-contained black box unit, right? Do you run the wires to the main 4 speakers through the basslink or still directly from the HU?
Gurgen
Old Apr 14, 2004 | 05:48 AM
rcanedo's Avatar
Yes, it's a self contained box....see pict above.
You do not wire the 4 main speakers through the sub. Just need to tie into the signal going to the Amp, or rear speakers. If you just tie into the rear speakers, the bass will be dependant on the fader. Just keep that in mind. Not difficult at all, and the instuctions that come with the Basslink is very good.
Old Apr 14, 2004 | 10:25 AM
justICE's Avatar
Looks like it only has low inputs. So pick up a high/low converter (LOC) and your set.
"I'm not saying you're full of BS, per se" - Zimbo
-JustICE
Old Apr 14, 2004 | 11:13 AM
rcanedo's Avatar
Actually has both high and low inputs, so no need for a converter.
Old Apr 14, 2004 | 01:00 PM
GurgenPB's Avatar
This is perfect for me, so I do NOT need an LOC, jus tap the line going to the right or left REAR speaker and that's it!?
And someone said that this one is about $75? That's perfect. Where?
Your advice has been great thanks again
G
Old Apr 14, 2004 | 01:02 PM
GurgenPB's Avatar
Also, guys, when I install the sub in, I should make sure that the low end does nto go to the in cabin speakers right? Are there capacitors or smth that I need to buy and connect in line with the inputs to the main speakers that will cut off the low end frequencies.
Gurgen
Old Apr 14, 2004 | 02:29 PM
rcanedo's Avatar
Actually, it's around $200 or above. Etronics has it for $209 here: http://www.etronics.com/product.asp?...de=infbasslink
The $75 sub needed a separate amp, and enclosure. Sorry for the confusion.
The Basslink has built in low pass filters, so you don't need anything in the line, just hook it straight to the high inputs. It takes care of the rest. You will need to run the Power cable to the battery, and will need a grounding point on the body of the car in the trunk. Follow that link above to learn more about that all in one sub.
Old Apr 14, 2004 | 08:38 PM
GurgenPB's Avatar
Again
thanks a lot guys, this is very helpful. Gurgen
Old Apr 14, 2004 | 11:01 PM
SoCaLG35Mashin's Avatar
MB Quart or Boston Acoustics
04 6MT Coupe
35% Madico smoke tint /CF Hood /Injen Cat-back
Old Apr 14, 2004 | 11:04 PM
GurgenPB's Avatar
So the stock sizes are 6x9 in the back and 6.5" in the front, right?
Gurgen
Old Apr 14, 2004 | 11:12 PM
tgenius's Avatar
no.. 6x9 is for the coupe.. sedan has no speakers on rear deck (cept sub) and has 5.25s for the rear doors
Old Apr 14, 2004 | 11:48 PM
hksjza70's Avatar
My recommendation is to go to your local audio shop and listen to the speakers on the board . . . name brands are all fine and dandy, but you gotta get what suits your taste and budget best . . nobody could tell you otherwise
Old Apr 15, 2004 | 12:09 AM
GurgenPB's Avatar
Thanks I'll do that
Old Apr 22, 2004 | 09:05 AM
  #30
Hey_Ya's Avatar
What would you audio guys think about installing the Focal utopia 165w in the front and the Focal 5ws in the rear doors? I plan on using the stock h/u and a precision power dcx 600.4 amp. I want a decent full range setup, no need for a sub right now.
Sorry for the hijack, I haven't gotten much respons on other posts.
Thanks
2004 Diamond Graphite Infiniti G35 Sedan
Z Intake Tube
5% Tint
ZAINO
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
f22raptor
Mar 18, 2016 08:50 AM
dseet
Oct 11, 2015 12:40 AM
RWDguy4238
Sep 30, 2015 12:13 AM
Detailed Image
Sep 28, 2015 07:04 AM
