OEM bracket with Z2 install not so perfect...
Old May 11, 2008 | 12:11 AM
satanklawz's Avatar
Ok, it has been said that the OEM bracket will work fine with aftermarket DD installs like the Z2. Well tonight I ripped into the car with a vengeance and had the factory radio out and out of the bracket in about 10-15 minutes. I slid the Z2 into the bracket and 3 of the 4 holes lined up perfectly so I said oh well at least I have 3 and the pioneer manual even states "3 or 4" so I figured I was fine. I then grab the finisher and slide it on and it appears that the Z2 is sitting too far back. I removed the finisher, take the screws out and examine the other mounting holes on the Z2. I try and try and none of them will line up to make it any better. WTF!?!?! here is a pic...
BTW, I am using the factory bracket that came in my 06 g35 sedan with the NON bose NON navigation system.
Old May 11, 2008 | 02:19 PM
ON's Avatar
ON
The Z1/Z2 is tucked in a little. I"m not sure how other DD HU are, but that's just the way it is for the Z1/Z2.
Old May 11, 2008 | 02:26 PM
satanklawz's Avatar
Really? on other installs it looks a lot more flush than it does in my picture. I am going to mod the bracket to make it sit right where I want it to. I cant have it looking all jacked up like that.
Old May 11, 2008 | 11:10 PM
Skyline_G35's Avatar
English dude, English
If this makes you feel any better. I have a 03 and put the single din avic n1 in about 4 years ago. It didn't line up with the factory bracket either. I marked where the holes needed to be and took a drill and drilled a couple new holes in the factory bracket. Worked like a charm.
Old May 11, 2008 | 11:59 PM
satanklawz's Avatar
thats what I plan on doing...
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
jeffbdye
Jun 1, 2018 03:51 PM
Oregon13
Audio/Video/Electronics
Mar 1, 2016 12:06 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
