Airbag Warning Light
Old May 17, 2008 | 11:50 PM
earth0's Avatar
Thumbs up Airbag Warning Light
any help would be apprecite.Airbag warning light today.after trying to install
Nav-Bypass but could not complete after install back Airbag warning Light came up.Afteri have unplug the battery.It still came up.any sugestion will be appreciate.
Many Thanks for joaquin03!!!!! otherwise i couldn't fix it.THX!!
Here is the way how to fix the Airbag Warning Light. for all G35ers
Pls.follow these step.
Turn the key to the on position and watch the airbag light. It should stay solid for 5-7 secs, and then turn off, and then start to flash.
To reset the light, you must turn the key to on, watch the airbag light stay solid for 5-7 secs and as soon as the airbag light turns off, turn the key to the off position (you have to turn the key to off before the airbag light starts to flash, or you must start over). You need to repeat this 5 times. Try to start the car, and hopefully the light will be reset.
Old May 18, 2008 | 12:33 AM
phatbuddha's Avatar
My airbag light is on as well. Since I disconnected the factory amp and whatever the hell it is that sat on top of it. Let me know what you find out bro.
Old May 18, 2008 | 12:35 AM
Joaquin03's Avatar
Staff ALUMNI
refer to this thread for your problem..
https://g35driver.com/forums/showthr...t=airbag+light
found it with a 5 second search...
Old May 18, 2008 | 01:47 AM
earth0's Avatar
Hey! Thanks a lot!! I meant Very much appreciate.I thought i have to tke my G to the dealer.WOW!! It's all work!! Two thums up!!
Old May 18, 2008 | 01:55 AM
earth0's Avatar
Thumbs up
I just got it fix.And it work great now.try thisOMO
Old Jun 6, 2008 | 06:58 PM
pumbaa944's Avatar
Thanks for the tip, I unpluged the passenger airbag when removing the glove box for my iPod install (I know read...). Saved me a trip and $80!
Old Aug 29, 2013 | 06:09 PM
Derzigster's Avatar
Thanks so much for this fix. Worked like a charm first time
Greatly appreciated!!
Luisgalvan33
Jul 19, 2018 08:16 PM
leli_11
Aug 10, 2015 08:25 PM
mjfenix
Jul 17, 2015 02:07 PM
