Audio problems... need help.
Old May 21, 2008 | 09:10 PM
elpibe's Avatar
I put in my amp and subs in my 03 coupe, about a week ago, and when the subs are on, the car idles lower than normal, sometimes as low as 400 RPM's, and the subs sometimes don't hit, they are silent when they should hit. The battery that i have doesn't look very good(i just bought the car). I figured the car would be able to handle the amp and subs that i have, but I think i will either need to put an optimum battery in, or put a capacitor in. What do you guys think?
Old May 21, 2008 | 09:33 PM
lov3rboy408's Avatar
my friend you need a capacitor...100% sure!!
Old May 22, 2008 | 07:09 AM
antonucci's Avatar
how many watts is the amp pushing?
Old May 22, 2008 | 08:04 AM
WACK BEATS's Avatar
Are capacitors easy to install? I think i might need one too. (sorry if im thread jacking)
Old May 22, 2008 | 08:41 AM
Hi-TechG35's Avatar
^caps are easy to install. To the OP defainately change your battery and invest in a capacitor ASAP. Also check your wiring and make sure the speakers are wired correctly to the amp.
Old May 22, 2008 | 01:43 PM
Meatshackle's Avatar
Deep Sea Moderator
How many watts are you running?
You can probably forget about the cap and just change your battery.
Old May 22, 2008 | 05:01 PM
Gilley's Avatar
Did you connect everything yourself? How did you wire it and what equipment do you have?
Old May 22, 2008 | 10:13 PM
how big is your GROUND Cable?? did you do it right?
to help your questions.. be more specific
AMP = how many watts?
Sub = ohms, watts???
how many speakers you running etc..etc..
Old May 23, 2008 | 02:25 AM
blues's Avatar
battery or a bigger alternator.capacitor will help but in the long run depending on how much power you are pushing you will need to upgrade.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
MrIP35
Nov 8, 2015 10:47 AM
Jcruzg35
Sep 26, 2015 04:47 PM
