Is there a DIY for changing the G's car battery?
Old May 30, 2008 | 06:00 PM
emtguy05's Avatar
Question Is there a DIY for changing the G's car battery?
My battery is dead and i'm headed to the store to buy a new one. Is there a DIY? or is it pretty basic? How long does it take and what tools do i need?
Old May 30, 2008 | 06:21 PM
Glex25's Avatar
Administrator
10MM to loosen up the battery terminals.
Mini flathead or skinny flathead to remove the clips holding the cover
that pretty much covers it.
Old May 30, 2008 | 06:24 PM
whoakevin's Avatar
The recommended practice when removing a car battery is to disconnect the ground connection first and then other terminal. This ensures that a short circuit will not occur by a wrench touching grounded engine parts while disconnecting the other terminal. Similarly, the ground should be connected last when installing a battery. Remove the old one, replace with new one. Simple as that.
Old May 30, 2008 | 07:03 PM
G SEDAN's Avatar
its a lil tight in there...take your time, dont drop any bolts, have fun!
Old May 30, 2008 | 09:48 PM
emtguy05's Avatar
damn well I got lazy and just decided to have the pep boys do it! lol
Old May 31, 2008 | 05:22 PM
KPierson's Avatar
As long as you use a battery that is the same size as stock it isn't a big job at all.
I went with a red top Optima that was a few inches shorter. It was short enough thet the OEM tie down bar wouldn't hold it down, so I had to raise the battery tray up about an inch.
chinee
Jun 10, 2024 07:48 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
newg37
Jul 26, 2015 09:32 AM
ClwMike
Jul 23, 2015 12:55 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
