AM/FM reception problems with Kenwood head unit
Old Jun 3, 2008 | 10:29 AM
marcinr's Avatar
20 Year Member
Hi Guys,
I installed a Kenwood DNX5120 a few months ago, and my radio reception sucks; range is far worse than with the OEM radio. Stations which came in fine before are now a noisy mess. I used the Crutchfield antenna adapter to connect the antenna.
I'm out of my depth when it comes to car electronics, so where would you suggest that I start looking at tracking down this reception problem? Are there any connections that are especially critical to radio reception?
Old Jun 3, 2008 | 11:46 AM
Gilley's Avatar
I bet you didn't connect the power antenna lead. Even though these cars don't have power antennas, there is an antenna booster that needs to be powered.
Old Jun 3, 2008 | 01:03 PM
marcinr's Avatar
20 Year Member
You're right, I didn't connect any power antenna leads. Where do I connect it to, though?
Old Jun 3, 2008 | 02:15 PM
Gilley's Avatar
If you used a wire harness adapter, there will be a wire on the harness and a wire from your Kenwood. Connect them together.
Old Jun 14, 2008 | 06:41 PM
marcinr's Avatar
20 Year Member
Thanks a million for your advice. I removed the head unit today to see what was going on, and I did indeed forget to solder together the antenna power lead. Now that it's done, the radio reception is great!
Old Jun 15, 2008 | 08:48 PM
Gilley's Avatar
Glad it worked out.
Old Aug 5, 2008 | 11:09 PM
naughty240's Avatar
Yup I did the same thing. I was already to get HD or Sirus lol I guess ill have to take it apart tomorrow. I saw the power att wire but just assumed that was for cars with antenna mast setups.
Old Sep 5, 2008 | 05:38 PM
edirty5's Avatar
I have the same problem too. I have the bose sound system in my g35 and after I installed my kenwood dnx5120 the am/fm sucked. If I follow the steps above will it work. Because some audio guy tells me there isn't much you can do because I have the "bose system."
Old Sep 5, 2008 | 07:38 PM
Gilley's Avatar
Who are you going to believe, the people that have connected the power antenna wire and improved their radio reception or the installer that apparently doesn't know that it needs to be connected and blames your problem on the Bose system.
Old Sep 5, 2008 | 10:49 PM
edirty5's Avatar
I believe you man all the way. I think the guy just wants my money. I had pros install it so could you again tell me how to exactly do it cuz im not to sure at all and I dont wanna mess anything up and all
Old Sep 6, 2008 | 06:44 AM
Gilley's Avatar
It's simple. Have him connect the power antenna lead coming out of the Kenwood to the power antenna lead on the wire harness adapter, assuming he used one.
The G35 antenna has a powered amplifier that needs to be turned on. Even the non-Bose systems have the antenna amp, so the installer's statement that the static relates to the Bose system is not true.
Old Oct 17, 2016 | 05:40 PM
Iagent's Avatar
I put power to the harness antenna wire, and the FM is ok, but AM (which I really want) is 50% of what it was with the Non-Bose head unit. I can't figure it out. I hate not being able to listen to my AM radio.
Old Oct 18, 2016 | 10:16 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
What are you using to power the antenna? If you're using a new headunit's "remote" or "power antenna" signal wire, it's a SIGNAL wire and very likely doesn't have the power to actually power the antenna amp.
Old Oct 18, 2016 | 10:31 PM
Iagent's Avatar
Since I thought that maybe the power for an extendable antenna might be short term, I used the power (hot)
wire for whenever the unit is on line, (hot when stereo is on). I really think I may need to check the power to the antenna at the booster, but I really don't know where it is. I will do whatever it takes, because I really like morning AM.
Old Apr 20, 2022 | 08:42 PM
mick's Avatar
standard audio harness
kenwood Blue ANT wire 12V
how do i find the antenna booster to connect kenwood ant cable/blue, i guess there is no wire in the original harness ????? this is for reception problem and yes 12V on blue wire.thanks, mick
