Remote wire help
Old Jun 21, 2008 | 09:48 PM
CLiX`G35's Avatar
Remote wire help
the light blue remote wire from the stock HU wont turn off when the car is off. so my HU turns off but my 3sixty.2 and both my amps are still on. Any one have a clue ?
Old Jun 21, 2008 | 10:27 PM
mbritt80's Avatar
use the light green, thats the factory remote wire
Old Jun 23, 2008 | 11:33 AM
CLiX`G35's Avatar
I checked that and I am tapped into the correct wire. I had this system working fine..... unfortunately my car was in an accident and when it came back from repair the signal from the remote would not turn off.
I have an 07 5at g35c with the Bose system, i tapped into the bose remote and used that.
Anyone have any idea were the power source for the remote wire comes from and were it runs?
They changed the airbag cpu could this somehow be involved?
Anyone have access to a very through wiring diagram ?
Thanks
Old Jun 23, 2008 | 08:34 PM
CLiX`G35's Avatar
bump.... cmon someone here needs to know.. i stayed in the car and noticed that even when all the lights turn off the remote wire stays powered .
Old Jun 23, 2008 | 11:11 PM
Gilley's Avatar
You can download the service manual at www.infinitihelp.com
Old Jun 23, 2008 | 11:15 PM
CLiX`G35's Avatar
thanks gilley ill try that
i took a volt meter to it and with the car off i am getting a 12v read.... isn't the remote supposed to be around 4-7v ?
Old Jun 24, 2008 | 08:07 AM
Gilley's Avatar
The turn on should be 12 volts, but it should turn off with the radio.
As a last resort workaround, you could just wire the turn on into a switchable fuse in the fuse panel. The amp would always be on whenever the car is on, but that shouldn't be a problem.
Old Jun 24, 2008 | 12:17 PM
CLiX`G35's Avatar
thanks Gilley i might have to. What i am trying to figure out is how that wire stays on if it is suposed to be hooked up to the radio. ....
Old Sep 22, 2008 | 10:34 PM
vinflouen's Avatar
Hey can I ask a question real quick.
how do I get my amps to go on when radio goes on? Right now they are on all the time and I dont like it. How would I do this?
I have 2 Eclipse, one XA4200 and one XA1200.
thanks
Old Sep 22, 2008 | 10:51 PM
Gilley's Avatar
thanks
If you have the Bose system, it has an amp turn on wire. If you don't have the Bose system, you may be able to tap into the antenna amplifier turn on wire.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
9tray turbo
Sep 29, 2015 10:22 PM
the93owner
Sep 28, 2015 10:37 PM
