car will not start
Old Jun 29, 2008 | 09:37 PM
WGS's Avatar
WGS
Not Yet
Old Jun 29, 2008 | 11:02 PM
Meatshackle's Avatar
Deep Sea Moderator
What are the 2 white and 1 green for? Seems like a lot of grounds.
Old Jun 30, 2008 | 09:15 AM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
connect eveything back like stock, off the 12V lighter and see what happens.... maybe shortcircuiting off cigarette lighter wires...
You might want to take it to Autozone or somewere that has OBDII reader who can give you fault codes. That way you can pinpoint exact problem where shortcircuit is. Did you check fuse block near in front of the battery as well as the driver foot well near the dead pedal?
keep us posted....
Old Jun 30, 2008 | 11:34 AM
WGS's Avatar
WGS
the two white and green wires are from tvandnav2go. Last night I disconnected battery and today morning same thing, no go... Called towing and they taking the car to the dealer. I will let you know.....
thanks for your help
Old Jul 1, 2008 | 05:24 PM
WGS's Avatar
WGS
Hi again,
the dealer told me, that ground was loose or dirty and the car has several grounds, any way they reprogram the computer and every thing should be o.k.
I'm typing from work and my daughter is picking up the car.
Weird.....
thanks again
Old Jul 1, 2008 | 08:44 PM
Deep Sea Moderator
That would have to be a seriously dirty ground to keep the car from starting. Hope everything works out and doesn't cost you a lot.
Old Jul 2, 2008 | 09:22 AM
WGS's Avatar
WGS
I'm not the expert, this is the invoice "found codes #U1001/U1000. Repaired ECM ground terminal". Total cost $348.60 plus towing $230.0 for 20 miles. And The extended warranty does not cover it, bc nothing was brocken.
Old Jul 2, 2008 | 10:23 AM
docron1's Avatar
I guess the most important question is "Does you car start up now?"
It looks like they did the OBDII scan and found those codes U1001 and 1000. I'll try to doing some research in the service manual on these codes.
doc
Old Jul 2, 2008 | 10:36 AM
Hi-TechG35's Avatar
Geesh glad everything worked out.
Old Jul 2, 2008 | 02:32 PM
WGS's Avatar
WGS
thanks,
sure, car start up and seems to be o.k.
Old Jul 27, 2008 | 12:29 AM
princcipepersia's Avatar
Guys, I'm having the exact same problem. I checked all the grounds. This only happened after I tested the reverse camera by simmply putting the car in reverse. When I didn't see a picture I turned it off and now it won't start. Any ideas?
Old Sep 15, 2008 | 01:53 AM
figured it out.
Hey guys, in case it helps anyone I wanted to write back with an update of how I fixed my car. It was a fuse in a hidden fuse box. The one under the battery to be exact. Because of that 1 fuse the whole car wouldn't start. I couldn't believe it! Good thing I was only without a car for 2 days.
chinee
Jun 10, 2024 07:48 PM
newg37
Jul 26, 2015 09:32 AM
itschuckster
Jul 25, 2015 08:07 AM
kenthung
Jul 21, 2015 05:56 AM
realtalk21
Jul 20, 2015 09:07 AM
