where is the factory ground wire located?
i read my amp manual and it says its a good idea to upgarde the factor ground wire coming from my engine, does anyone know where that would be? they say most cars come with 10-16 awg wire for the ground, i want to replace it to a 4 awg wire...
Re: where is the factory ground wire located?
The manual is most likely referring the the cable between the battery and the frame. The metal body of the car is grounded because the negative terminal of the battery is connected straight to it. I've never looked at the battery that closely, but it's worth a shot. Another thing to keep in mind is that this ground wire is typically less then 18" long. At short distances higher guage wires can carry a significant more amount of current. 4 gauge would be overkill. 8 gauge is all you should ever need, at least with the stock alternator!
Kevin
04 Diamond Graphite Coupe - FULLY loaded
Windows up with OEM Remote
RE Short Shifter // Z Tube
Kevin
Whats interesting about the G35 is that the ground from the battery only goes to the fender. In all the other cars I've owned there was always two grounds one to the fender and one directly to the engine block. This has been the case for Ford, Chevy, Toyota, Lexus, Acura. I wonder if it's a Nissan thing?
maybe that's why the grounding kit [supposedly] has more gains for this car/350Z than most cars out there.
2004 Twlight Blue/Willow 6mt Coupe.
Bel Vector 985 Hardwired.
Grounding Kit.
Splash Guards.
Next Project: Carputer.
Grounding Kit.
Splash Guards.
