Move Nav DVD Rom to Trunk?
Old Apr 26, 2004 | 08:08 PM
G35SanDiego's Avatar
Anyone done it yet? What I would like to do is move the nav DVD ROM from the cubby hole above the glove box to the trunk and put a dvd player in the open hole (with a little modification) where the NAV used to be. Does anyone know what this would involve? Besides the need wiiring are there any hangups that you can think of? Also come to thinko of it, what is in the DVD ROM location for those without NAV?
Old Apr 26, 2004 | 08:12 PM
rieskame's Avatar
Re: Move Nav DVD Rom to Trunk?
Im pretty sure it is just another cubbyhole
Old Apr 26, 2004 | 10:45 PM
Meatshackle's Avatar
Deep Sea Moderator
There are about 3 wiring harnesses connected to it. You'd be better off mounting the dvd player somewhere else and running 3 wires you can buy at walmart instead of 30-40 wires that will be a pain in the a$$ to find.
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest Monitors Thread
Old Apr 27, 2004 | 06:30 AM
djrobx's Avatar
The spot where the factory nav DVD goes is such a sweet spot for other gear. And since you rarely ever need to get to the nav DVD drive, I can easily see why people would want to move it. I'd much rather have my EQ in there.
-- Rob
Old Apr 27, 2004 | 04:10 PM
MyGUnit's Avatar
russ,
can u elaborate please
thanks
Mitch
2004 G35C AT
Blk/Blk
Prem.Aero.Perf.Nav
Nav/TV Tuner w/ PS 2
2-10" Subs w/ Rockford Amp
Clear Corners
Pop Charger
Z-Tube
Old Apr 27, 2004 | 05:54 PM
Deep Sea Moderator
I'm just saying that there are 3 different wiring harnesses each with several wires (10-15). It would be a pain to match those up, extend them and re-fab a housing for a dvd player when you could just put a dvd player in the armrest or glove box.
Russ
Black 6MT Coupe
Jax, FL
Old Apr 27, 2004 | 06:26 PM
RamboRami's Avatar
G35driver.com Moderator
dont forget that the nav system has a gyro and speed sensor, so by moving it, you have to make sure it is level and pointed in the right direction, although im sure there is a way to calibrate the direction, but the angle of mount needs to be level or near level (+/- 10 degrees usually)
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake
Old Apr 27, 2004 | 09:33 PM
Noremac's Avatar
The compass and speed sensor are not integral to the Nav DVD/CPU unit.
But overall, I can't imagine making extension bundles and connectors for this job. This would be tedious work, and unless National Security is at stake, falls into the "Mission Impossible" category!
<font color=blue>'04 G35S 5AT, Black Obsidian/Willow, Prem/Nav/Sat</font color=blue>
Old Apr 28, 2004 | 07:41 AM
crashTestDummy's Avatar
you guys think with a little cutting and fabrication, a ps2 will fit in that upper glove box?
DP G35 coupe/ AT / Prem graphite / Sport / Titanium 19 tint / 5 wire hyper-ground kit / clear corners / hyper white clearance/ i-Pod mini silver
San Diego, CA
Old Apr 28, 2004 | 07:52 AM
Deep Sea Moderator
Tried the ps2. It won't fit unless you modify/remove the door and cut out the entire ps2 housing.
Russ
Black 6MT Coupe
Jax, FL
Old Apr 28, 2004 | 11:33 AM
RamboRami's Avatar
mount it at the bottom passenger side like that one guy did in his "PS2 and headrest monitors" thread, it was a stealthy install
Old Apr 28, 2004 | 01:08 PM
vipergda's Avatar
I have the sedan without the nav and I did put a playstation 2 in that spot it takes a lot of work to the playstatio but it can be dun you have to modding the motherboard to make it smaller but u can get it to fit without cutting any thing in the car it looks really cool if you are interested in seeing it I could maby post some pics
Old Apr 28, 2004 | 03:48 PM
Yah, fo sho. Please post pics when you can. I took apart my ps2 a while back to see if I could re-arrange it's components, but didn't think it could be done. Now you got me all excited about mounting my ps2 in the upper glove. Lookin at putting my xbox either under the bottom glove or in the trunk. Any suggestions?
San Diego, CA
Old Apr 29, 2004 | 02:49 PM
vipergda's Avatar
here are some pics sorry they took me so long
Old Apr 29, 2004 | 02:54 PM
vipergda's Avatar
pic 1
