Circuit Board Compatibility? Sedan-> Coupe?
Jul 8, 2008 | 05:40 PM
Hi Guys
I have a 2003 coupe w/ nav/sat and I need my circuit board replaced.
Can I use one out of a 2003-2004 sedan? Any stipulations? Also can the circuit board be separated from the finisher and installed onto another?
Reply 0
Jul 8, 2008 | 06:31 PM
I think if you make sure you have the same type of radio - Bose for Bose and standard for standard - you should be able to swap circuit boards just fine. The Bose board may even be compatible with the standard radio.
Check with the Infiniti parts department and see if they have the same part numbers.
Reply 0
