05 MT sedan double din/new amp/new speakers comprehensive guide on BOSE system?
I have been searching for an hour now. I've read all the options and answers...but, no how to guides for the speakers and wiring...
This is what I have found:
removal of existing HU and replacement items needed for HVAC controls, steering wheel controls, wiring harnesses, antenna, etc.
Options available to us regarding speakers(front, rear, deck) and bose amp replacement etc.
This is what I need:
How to replace those speakers, remove the bose amp, run wires to the back of the car etc. Any guides anywhere?
Also, for those with a sedan and a sub in the back, how is the vibration. As bad as the older Maximas? Remedies?
Thx!
Thx!
If you're installing a new HU, you just bypass the Bose amp altogether because you'll be running RCA cables from your new DD HU to your new amp.
If you want to usethe stock speaker wires, there is a good post somewhere that shows how and where to tap into the Bose amp speaker outputs.
You're going to want a sub in an enclosure in the trunk. Replacing the stock sub in the rear deck isn't a good idea for the best sound.
To remove the speakers, remove the door grab cover piece, remove the screws under there, remove the screw where the door opening lver is, pull the panel out and up to expose the speakers. You should get MDF speaker spacers to space the front of the new speakers to the back of the plastic panel.
mjfenix
Aug 17, 2017 05:49 AM
Thunderaan
Jul 22, 2015 07:40 PM
