Anyone running a Custom Box for a Sub??
Old May 4, 2004 | 07:55 PM
tgenius's Avatar
I am having issues with the bass coming from that Qlogic box and my JL 10W04... the installer says that the reason the bass sounds bad with some sounds and not others .. and he says the Qlogic box isn't designed for it since its a universal box and that a custom box for my trunk would make it sound great and only take about .75 cubic feet! Any suggestions/comments?
2004 G35s 5AT DG/Graphite/Premium/Huper Optik Tint
Old May 4, 2004 | 11:12 PM
bun84067's Avatar
Re: Anyone running a Custom Box for a Sub??
Hmmm. I don't buy it. I think the store is trying to sell you something.
Find songs that you know sound good on a friends system, and play 'em in yours.
Old May 4, 2004 | 11:26 PM
tgenius's Avatar
I think I found out what it is:
Since I'm running my sub off the rear channels... the Sub is picking up the lows AND the bass.. so David Navone suggested I disconnect one of the RCA's for the sub. Since a true bass note hits on both channels, I'll still get the bass, and only half of the lows.. which I think will help CONSIDERABLY!
Opinions??
Old May 5, 2004 | 10:54 AM
Will_blueprint's Avatar
get a crosover too
Old May 5, 2004 | 11:43 AM
Anonymous's Avatar
I agree with the initial suggestion. I think its your box that is exxagerating some lows. Try a different box facing rearward before you spend money on a custom, or better yet, get a JL Audio Stealth box which will be out in a couple of months. It's a 12" sub firing downward and it goes where the Bose amp is now. You wont even be able to see it. It'll cost you between $500-600. Cheaper than a custom box I'm sure...Hope this helps...
Anonymous's Avatar
Old May 5, 2004 | 12:03 PM
tgenius's Avatar
Bose amp on the sedan is under the rear deck
After disconnecting one of the lines from the sub (I had both L & R hooked up) it seems to of helped ALOT..there's still some residual.. the point here is the following:
The Qlogic box is .65 cubic feet, the custom box will be .75 cubic feet. The cost of the custom box is $125 installed, versus the 65 I paid for the Qlogic box. I CAN return the qlogic box and go with the custom box if I want, and the carpet match will be 100 percent.
Is the .10 cubic feet (and probably more importantly, the shape of the enclsosure) a difference maker??
Old May 5, 2004 | 12:17 PM
bun84067's Avatar
Crud. For $60 I'd make the switch.
I don't think the size matters, it's all about volume. .65 to o.75 is 15%. That's probably significant.
Old May 5, 2004 | 12:27 PM
shibal_z's Avatar
Just goto the JL website and look at the recommended volume requirements for your sub. As for the shape, I've read elsewhere that perfect cube or squarish boxes are not optimal due to the sound reverberations happening within the enclosure. A wedge or some oddly shaped enclosures do better to increase SQ. Remember to take into account the volume that the sub takes when calculating enclosure volume requirements.
<font color=red>Shibal G-Thang</font color=red>
<font color=blue>'04 TB 6MT Graphite: Aero Pkg, Premium</font color=blue>
Old May 5, 2004 | 05:00 PM
doughster's Avatar
Re: Anyone running a Custom Box for a Sub?? *DELETED*
Post deleted by doughster
Old May 5, 2004 | 05:23 PM
tgenius's Avatar
the amp crossover is being used and its set to 90 or 100khz according to the installer.. I've got an appointment on saturday morning for them to build me a box and get rid of this crappy qlogic
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
mtlruss
Dec 20, 2015 01:51 PM
Frostbite91
Aug 2, 2015 04:59 PM
G35Sask
Engine - Intake/Fuel
Aug 1, 2015 11:16 AM
