Aftermarket Stereo
Old Aug 27, 2008 | 04:39 PM
lucchesi22's Avatar
Smile Aftermarket Stereo
Hello, I have a 2003 G35 Sedan with BOSE system. I would like to install an aftermarket stereo. I was told I could not do this because the A/C and the stereo are 1 unit. But I know it is possible. What parts do I need?
Old Aug 27, 2008 | 04:42 PM
naughty240's Avatar
Read stickys in audio sub forum..... there you will find your answers.
Old Aug 27, 2008 | 04:49 PM
az1anbeethoven's Avatar
^^+1
anyways, in a nutshell, you will need:
JDM DD finisher
JDM AC controls
DD head-unit
Pac unit for retaining steering wheel controls
and it should come out something like this:
Old Aug 27, 2008 | 04:52 PM
Boston's Avatar
OP, we're assuming that you want a Double Din?
Old Aug 27, 2008 | 05:14 PM
suzuk1girl's Avatar
Originally Posted by az1anbeethoven
^^+1
JDM DD finisher
JDM AC controls
DD head-unit
I use the same air freshener
Old Aug 27, 2008 | 05:23 PM
^^yea...haha..$3 does wonders..and refills are like $1.50 at target.
Old Aug 27, 2008 | 06:02 PM
OCG35's Avatar
^^^ X2... and I thought I was bad about going off topic
Old Aug 27, 2008 | 06:27 PM
Fabrikator's Avatar
i used this dash kit from Metra.. it retains the dual climate controls unlike the JDM dash.
http://www.amazon.com/METRA-99-7604-INFINITI-2003-2004-INSTALLATION/dp/B000WCI422 http://www.amazon.com/METRA-99-7604-INFINITI-2003-2004-INSTALLATION/dp/B000WCI422
the color matches perfectly
Old Aug 27, 2008 | 06:30 PM
^^negative sir, the JDM dash does come with optiona dual now...and the metra kit has the cheapy buttons so i rather spend a little more for OEM
Old Aug 27, 2008 | 06:31 PM
Actually, there is a scent that smells like the cx-3 squash...so it's well worth it imo
Old Aug 27, 2008 | 06:39 PM
naughty240's Avatar
Everyone talks about the squash air fresheners. Ima have to grab one. Are they the JDM ones?
Just say no to the cheap Metra kit.
Old Aug 27, 2008 | 06:51 PM
reconJDM's Avatar
you got a link to the JDM DD kit with the dual climate button?
I need one
Old Aug 27, 2008 | 06:55 PM
OCG35's Avatar
When I first got the car I looked into upgrading the stereo… then got sidetracked with performance mods… then got side tracked by cosmetic mods… now I guess I should consider audio again…
I don’t drive the car much and therefore don’t use the stereo much – so I don’t need anything hard-core… is there any value in just upgrading the speakers and keeping OEM head unit?... If so – is there any value in adding a small amp with OEM head unit? Again, I’m not interested in an @ss kickin’ system – just clean sound and maybe a bit higher level/volume capability…
Old Aug 27, 2008 | 06:56 PM
I need one
well, since you asked nicely, here it is:
https://g35driver.com/forums/accesso...c-control.html
Old Aug 27, 2008 | 07:03 PM
naughty240's Avatar
Dont he have an 04? I think he has to solder the part from his factory unit to make it work. Ill try and dig it up.
