How to find out if I have SAT or installed in my car
HI there
I have a imported 2006 Model (G35 Coupe) in Germany and I was wondering how to find out if I have the Sat installed in my car or not.Since I live in Germany the Sat will not work there at all but now I wanna install my PAC NIIS 2 Adapter with a aftermarket DVD Player and I dont know if I should put the switch on the PAC Unit for the SAT to off or on.
I hope someone can tell me how to find this out.
Theres also a blue/balck wire on the PAC harness which is for Aux 1 (-) remote output do I simply have to ground this one?
thanks for your fast answer.what do you mean with USDM.the car is imported from the USA.
I only need to know if I have to put the Switch on the Pac Unit to on or of for the SAT.
Ok thanks now I understand what you mean.
I already know that I have to install the Pac Unit behind the Radio Headunit but I still need to know if I have to put the switch at the Pac Unit to Sat or no Sat.And I also have to know if I have to connect the two cables on the PAC Unit which are not plug and play.
I just installed it yesterday. so if you have sat service then put the switch on pac to sat; otherwise, put it on no sat. The Sat button in your car is the switch to turn on /off for the pac so don't bother to put another switch. Good luck!!!!!!
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
stay_tuned
Jul 21, 2015 07:09 PM
