Lack of climate control
Old Sep 12, 2008 | 06:03 PM
Shakuya88's Avatar
I did some searching and couldn't find an answer to my actual problem. I am getting my DD headunit this monday. Issue is the JDM dash conversion is going to take 60-90 days. Im not very patient of a person. Would there be any harm in running the new radio without the JDM pieces. Including the AC controller? I'm assuming climate system would be stuck on something. What would that something be?
THanks
Old Sep 18, 2008 | 03:29 PM
NORTHTX's Avatar
you are going to have to have the JDM trim, your factory radio housing doesnt completely come out.
Old Sep 18, 2008 | 09:19 PM
Shakuya88's Avatar
I know I need the JDM pieces to have a finished looking dash. I can use the bracket off the stock radio so that I can mount it. I'm wondering how the climate control is affected. I know I won't have any control over it to change it but I'm wondering what it will be on.
Old Sep 18, 2008 | 09:32 PM
patman530's Avatar
change it to a reasonable temperature before you take out the unit, because it will stay at what you last set it as. when i was doing my install, it took a couple of days to complete, and i rolled around without the headunit/climate control. luckily it was set to a low enough temperature and the a/c was on (this was summer time).
Old Sep 18, 2008 | 09:34 PM
Shakuya88's Avatar
I was thinking it would be a memory kind of thing being mainly digital. So it will stay what I leave it at. THANKS! Now I can install the headunit this weekend!
Old Sep 18, 2008 | 09:45 PM
patman530's Avatar
i think as long as you don't disconnect your battery, the settings will stay
Old Sep 18, 2008 | 10:13 PM
Shakuya88's Avatar
Well the new radio has a brake bypass (i know we're not suppost to talk about that) but it's a pain to do so I won't be intentionally disconnecting battery. For awhile anyway.
Old Sep 20, 2008 | 04:47 PM
Shakuya88's Avatar
well, installed radio today. The controls do stay to last set. Only difference is I had it on Auto AC ECON and it changed to AUTO AC. no biggie.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
markbilo
Sep 30, 2015 01:33 AM
