Help!!Electronical Problem.. Center Console Chips In & Out??
I need some advice?? Just recently my G center console (stereo & AC) chips out sometime, and the AC would go on AUTO mode blowing pretty Hi and I would have to select my CD and stereo from the steering controls.. sometimes they go out for several hours. I am not sure if this problem has happened with any one in the past!! Is this something I should really worry about?? I checked the fuses and they all seem to be fine..
It is a common problem and it is bsomething you will have to get replaced. The radio/AC circuit board has likely shorted out and will need to be replaced. Sometimed the entire radio needs to be replaced.
If you car is under warranty, have the dealership fix it.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Learned Hand
Oct 1, 2015 09:02 AM
