passanger seat switch...
Old Oct 4, 2008 | 11:00 AM
jeremys14's Avatar
mine decided to crap out. my seat won't go back. it will go foward, as well as recline. has anyone else had this problem? and does anyone know where the part number?
Old Oct 5, 2008 | 09:14 AM
Gilley's Avatar
It the car is under warranty, take it to the dealer.
Old Oct 6, 2008 | 01:22 PM
jeremys14's Avatar
no warranty
Old Oct 6, 2008 | 06:10 PM
Blotto's Avatar
Mine is starting to have the same problem, it gets stuck at times, i keep messing with it until it goes back. No warranty for me either.
Old Oct 16, 2008 | 11:54 PM
dj prophecy's Avatar
My driver side switch is also acting up except it also causes the seat to move a inch or so on its own! Its like the chair is possessed.
Old Oct 21, 2008 | 10:22 PM
FISA's Avatar
Has anyone fixed this problem themselves ?
like a DIY ..
I have the same prob... my passenger seat will go front and back..
but will only recline front..doesnt go back
dealer wants $380 to replace the switch
Old Nov 2, 2008 | 10:52 AM
FISA's Avatar
Hmm..suprising that noone has tried to take a shot at this issue...
seems like quite a few ppl have had this problem...
I guess dealer it is....
Old Dec 4, 2008 | 12:56 PM
jimNC's Avatar
I have a pair of power seat switches from a 2003 G35 Coupe that I think I am gonna be selling. If anyone is interested, PM me. Both switches work.
Old Feb 7, 2009 | 10:58 AM
TripnG35's Avatar
Has anyone replaced the switch? If so can you provide some directions?
Old Mar 1, 2009 | 01:38 AM
RELICG35's Avatar
Hey guys I just fixed mine this weekend.I had a problem with my passanger side. It was stuck all the way upfront could not get it go back. Just let you know it's hell trying to unscrew the two front screws, since they are under neath the seat. Once you have the seat unsrewed take of the plastic part around the front. It's heald by two screws upfront. Now you will see the motor.
To take of the switch you will have to unplug the seat and take it out of the car have a blanket ready to set it on. On the switch side you will have to puncher two holes into the thin plastic were the screws are. Unscrew the two screws and the switch will saparate from the seat. The plastic around the switch will come off and just the black switch is left. Flip it over on the back of the switch it's heald by four sides pry each side gently and it will pop out now you will see the two small switches one for forward and one for backwards see if they are not rusted spray a little wd40 on it. Take the seat back to the car set it inside on it's side connect the white connection and try to move the seat switches. That's were my problem was it was rusted some one spilled somthing
Old Mar 1, 2009 | 01:49 AM
Z_IP_G's Avatar
^ good to know. bookmarked this for whenever mine craps out on me. thanks
Old Mar 1, 2009 | 01:51 AM
RELICG35's Avatar
I can move my seat back and forth but ones I put it back together it gets stuck so just left it without that grey switch and just use the two smaller white switches untill I have some time to tweek it. At least ppl can sit upfront now. Now if it's not the switch then its the motor. To unscrew the motor it has three screws ones you open it and see the coil inside see if the carbon brushes are good. It's tricky you would have to have some one who knows to look at it. Good fixing
PS sorry for the misspells using my iPod.
Hope it helps .
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
doakley92
Sep 25, 2015 12:58 PM
zcherub
Sep 10, 2015 12:03 PM
pasjr1972
Sep 1, 2015 10:17 PM
