Dimming Headlights (Wiring Question)
Old 10-05-2008 | 10:11 PM
Ktm.Moto's Avatar
Before I get flamed, yes I searched.
Ok, so I installed my system today using the DIY on this board. The only thing I did differently is run my remote wire off of a switch.
I am running an Alpine Type R 10"
Alpine MRP-M500 Amp
Stock headunit.
Anyways, my lights are dimming and I was wondering if the way I wired something could be the problem or not? My dad is really on my case because he thinks I am going to mess up the whole electrical system on the G. I just really want to stop this dimming. Any suggestions? Thanks in advance guys!
Old 10-05-2008 | 11:50 PM
JG35E's Avatar
You need to either 1... upgrade your alternator and battery or 2 (which is easier and way more cost effective) get yourself at least a 2 farad capacitor. It basically keeps a charge like a battery and feeds your amp a consistent power supply. So get "cap" and you will be all set.
Old 10-06-2008 | 12:01 AM
Xet's Avatar
Xet
do big 3 wiring upgrade first. cheapest and a good chance it will solve your problems.
Old 10-06-2008 | 12:04 AM
Ktm.Moto's Avatar
I don't think I would trust myself doing this. Would auto shops do this?
Old 10-06-2008 | 12:16 AM
jimrockford's Avatar
Most probably wouldn't know what you were talking about. A good car audio shop would be your best bet.
Old 10-06-2008 | 12:30 AM
Ktm.Moto's Avatar
Alright..Thanks guys.
Old 10-06-2008 | 01:16 AM
sfgr415's Avatar
Make sure you have good power/ground. Then do the big 3 upgrade.
Old 10-06-2008 | 09:53 AM
Triple8Sol's Avatar
I had this problem too, and installed a 1 farad cap. Seems to have stopped the headlights from dimming, although the interior lights still dim when the gain is up.
Old 10-06-2008 | 07:30 PM
Ktm.Moto's Avatar
Yeah I am going to try out my cousin 1 farad cap and see if it works. If it does, I am going to buy a nice Rockford Fosgate one. In the meantime will it hurt my car badly if I run it like this for a couple of days?
Old 10-06-2008 | 10:07 PM
Gilley's Avatar
Check the wiring of your sub and make sure that it isn't wired with too low of an impedance for your amp to handle.
I have an 8 farad cap I need to sell.
Old 10-06-2008 | 10:17 PM
Your stock wiring is too small to supply the current demands of your sound system. A capacitor may mask the problem but it won't eliminate it. On the other hand, the big three upgrade is simple, cheap, and fixes the source of the problem. It really should be your first step.
As far as your question goes, running your system with the lights dimming shouldn't cause any major problems in the short term. However, your amplifier is likely not putting out full power, as the electrical system is having trouble keeping up. I would keep the volume low enough that the lights don't dim.
Old 10-06-2008 | 10:25 PM
eljoker's Avatar
ok what is big 3? sorry for thread jacking but im confused usally i just add a "cap" or a better battery
Old 10-06-2008 | 10:32 PM
Old 10-06-2008 | 10:38 PM
eljoker's Avatar
^^^^ thanx
Old 10-06-2008 | 11:37 PM
Ktm.Moto's Avatar
Alright guys I appreciate the help. But I am confused how to wire my sub with the right impedance?
Quick Reply: Dimming Headlights (Wiring Question)
