big 3 question with pics
Old Oct 6, 2008 | 09:53 PM
MikeGrote's Avatar
how are you guys hooking up your big three wires? did you use the second bolt on the right in this pic for the pos to alt wire?
would that still utilize this 120a fuse right next to it?
and how did you run that pos to alt wire, did you cut a new hole through the metal? or cut another hole in that grommet? thanks
Old Oct 7, 2008 | 02:15 AM
Scrooge's Avatar
What size wire are you using ? Cause I would use the grommet thats shape like a "D" and drill a hole through that. Remember to follow the alternator wire and use wire loom and zip ties to make the installtion looks cleaner. Also attach your wires to the copper side, going the different direction.
Old Oct 7, 2008 | 08:48 AM
MikeGrote's Avatar
i was planning on either 2ga or 0ga. what do you mean by copper side? i think the copper you see in the pics is actually the connector connected to the wire
Old Oct 7, 2008 | 12:02 PM
Scrooge's Avatar
Yeah thats what I mean.
Old Oct 8, 2008 | 11:47 AM
G-4ME's Avatar
Is it safe to use that 2nd stud for a power wire for an amp? Looks like that stud is hooked up to the 120A fuse. Will this cause any problems?
Old Oct 8, 2008 | 01:07 PM
MikeGrote's Avatar
that was one of my original questions, is that second stud hooked up to that fuse?
Old Oct 8, 2008 | 01:08 PM
Scrooge's Avatar
Hook up a voltmeter and see if you get battery voltage at that stud. Then you can use it.
Old Oct 8, 2008 | 01:26 PM
MikeGrote's Avatar
if it were me, id use the post on top of the battery for your amp powerwire cause you will likely have a different size fuse that you will want to use. the second stud would be better for the big3 upgrade as it will already be fused, assuming that second bolt flows through that fuse
Old Oct 10, 2008 | 08:44 PM
MikeGrote's Avatar
anyone have any pics of their big 3? i looked at the batt to alt and its a pretty decent size wire already. and where are you guys doing the block to chasis?
Old Oct 11, 2008 | 01:42 AM
Scrooge's Avatar
Just look at my engine detail you see the grounds upgrade in the front.
Old Oct 13, 2008 | 09:49 PM
MikeGrote's Avatar
engine detail?
Old Oct 14, 2008 | 02:52 AM
Scrooge's Avatar
You can find it under the detail DIY section.
Old Oct 14, 2008 | 02:57 AM
jalilig35's Avatar
anyone ground the alternator? any pics how u did it with wire not goin throu the belts?
Nicksims13
Oct 15, 2015 01:57 AM
maximino
Aug 12, 2015 02:05 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
joel extreme
SOCAL Meetings & Events
Jul 27, 2015 11:59 PM
