Double Din Aftermarket
Old Nov 4, 2008 | 06:45 AM
blackberry1984's Avatar
I Was Reading In The Forum And I Saw Where You Can Install A Touch Screen Double Din In Ur Coupe Or Sedan But Ppl Were Having Trouble With There A/c Controls, Someone Posted A Site Where You Can Supposedly Buy The Finisher For The Center Console, And The A/c Control Which Works With Aftermarket Headunits. Does Anyone Know Of This Problem Or Had This Problem When Installing A New Headunit And If So How Did You Fix It?
Old Nov 4, 2008 | 10:41 AM
williamjv's Avatar
Blackberry,
You have two choices to go with (2 different DD Kits that is) one made by JDM (which I personally installed last week and had no problems what so ever) and the Metra Turbo 2 which is pretty much the same thing except the AC controls look pretty cheap but from what i've heard it works just as good as the JDM.
So to answer your question, you may choose either one of these 2 DD Kits and your aftermarket AC controls will work fine as long as you connect it properly (which is only one plug for the AC controls so you shouldnt miss it)
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Picture Share
Feb 4, 2018 12:41 PM
Oregon13
Mar 1, 2016 12:06 AM
BfloG35
Oct 16, 2015 05:22 PM
