Double Din Trim Plate - With JDM Kit or with Receiver?
Old Nov 7, 2008 | 10:37 AM
RiCeBrNr's Avatar
Hi Guys
I've recently installed an AVIC-F900BT with the JDM double din trim kit.
Neither package included a trim ring, which now leaves me with a little bit of a gap around the unit.
Is there a double din trim I can buy or did you guys fabricate one?
Thanks.
Old Nov 7, 2008 | 01:50 PM
williamjv's Avatar
RiCeBrNr,
We actually have the same setup and both have the same issue. Unfortunately i've been looking this ever since i installed the my new HU (F900BT) and I have not been able to find a solution. I know the DD Kit by Metra (Turbo 2) allows the F900BT to have a perfect fit and its about $120 cheaper "but" the ac control looks cheesy/cheap.
What i did to cover up mine was using a foam sheet from a computer motherboard i had purchased, i inserted strips of the foam sheet on the gaps to cover it. It is not the best looking solution but definately beats the gap we were left with after installing the JDM DD Kit and the new HU.
I'll try taking a pic and posting it so you can see waht i'm talking about.
Old Nov 7, 2008 | 02:05 PM
RiCeBrNr's Avatar
Originally Posted by williamjv
RiCeBrNr,
Thanks so much for the reply. I think you posted in one of my threads on avic411 as well.
I suppose the best we can do is fabricate something unless someone here has a solution.
Old Nov 7, 2008 | 02:10 PM
williamjv's Avatar
Probably,
I had started my own thread about a week ago (regarding the same issue) nobody provide a solid solution to mine so i'm guessing is not going to be an easy plug/play solution
https://g35driver.com/forums/audio-v...-dd-radio.html
Old Nov 24, 2008 | 10:36 PM
jpez179's Avatar
any pics with the jdm dd installed?
Old Nov 25, 2008 | 12:05 AM
RiCeBrNr's Avatar
With the avic-f90bt?
If so I can take a picture for you.
Old Nov 25, 2008 | 12:18 AM
jpez179's Avatar
yes with the avic 90bt installed...thanks!!!
jsimonk
Dec 22, 2023 03:49 PM
Plur
Audio/Video/Electronics
Jun 1, 2020 08:25 AM
WillisFL
Dec 29, 2016 08:56 AM
CHI-TOWNG35
Aug 19, 2015 11:47 AM
RA081024
Aug 18, 2015 07:03 AM
